Where to get HG job done?
Discussion in 'Modifications And Maintenance' started by MikeO, Oct 20, 2006.
  1. MikeO
    MikeO Active Member
    Golden Valley
    I've got a 98 Legacy OB, 2.5l with 90k miles. I "think" I may be in need of headgasket replacement. Here's the symptoms:
    1) Overheated out of the blue last week. Coolant all over engine compartment.
    2) Bubbling in the reservoir.
    3) exhaust smell in the coolant reservoir (not sure if that really matters)
    However,
    It hasn't happened since. Heater works fine. Coolant level fluctuates between hot and cold levels as it should.
    My local mechanic can't find any problems and doesn't think headgasket failure would cause the overheating. Don't think he knows Subaru's too well.
    Assuming my problem really is headgasket failure, can anyone recommend a decent place to have the repair done? I want it done right, but don't really want to pay dealer service rates.
    Thanks in advance!
    Mike
  2. LVT
    LVT Well-Known Member
    t3h f4sT
    if it has never had it's gasket changed before....then most likely, it's going out. I have never taken my car to any shops to do HG jobs so i wouldn't know. I do my own things. All the phase 1 2.5L had HG problems.
  3. MikeO
    MikeO Active Member
    Golden Valley
    Well it's in the hands of Morrie's Mtka now - if you're reading, do a good job guys!
    Mike
  4. AWDimprezaL
    Monticello.
    driftin240 is doing them! :)
  5. readymix
    Eloh, El
    Driftin240 = you win. You're in good hands.
  6. MikeO
    MikeO Active Member
    Golden Valley
    That's what I wanted to hear!
  7. driftin240
    driftin240 Well-Known Member
    Out West
    Thanks Yo!
    Mike, I got your heads off today, and they are being sent out. I got a couple of other things replaced as well...Rear access cover, and rear main seal. Oil pump will get re-sealed tomorrow. And then I'll just be waiting for your heads to come back.
  8. driftin240
    Out West
    BTW, you should go back and ask the "mechanic" how much coolant dye he added. Your coolant looks like it was toxic green waste and it seriously looked like it was glowing!
