Which Piston Size to Order?
Discussion in 'Modifications And Maintenance' started by 6MTizzle, Jan 2, 2007.
  1. 6MTizzle
    6MTizzle 2SLO
    South Side
    Please pardon my engine internal n00bness. In checking my invoice for my pistons it says Mahle Pistons .20 Over. I'm guessing this is not the correct size. These haven't been ordered yet but I wanted to make sure this is the direct stock replacement.
  2. Dream
    south
    99.5mm with standard bore, 100mm if your going to overbore. You need to figure out if you need to overbore the block before you order s0n.
  3. readymix
    Eloh, El
    .020 over means they are not Standard Size.
  4. 6MTizzle
    6MTizzle 2SLO
    South Side
    I figured as much...just wanted to make sure. I just sent Josh a pm regarding what to do on this.
  5. 6MTizzle
    6MTizzle 2SLO
    South Side
    You are 100 percent correct, sir :cool:
  6. 6MTizzle
    6MTizzle 2SLO
    South Side
    Thanks for the help guys. Hopefully all is well when we open her up. Worst case scenario though I have a little more displacement :biggrin:
  7. redheat86
    redheat86 Well-Known Member
    Granted subarus are a different world, its typical in hondas that if you are replacing the pistons to go with the .20 over.
    Its not always the case but if you dont you could end up having to run looser tolerances and a possibility of burning more oil.
    again, not always but could happen.
