Whining under accel, turning.
Discussion in 'Modifications And Maintenance' started by ArcticWolf, Feb 2, 2008.
  1. ArcticWolf
    ArcticWolf Well-Known Member
    Moorhead, MN
    Something I noticed tonight... only seems to happen during accel and turning, definetly from under the hood (its not gear whine, at least... location wise, the reverse whine is next to me, this is up in front of me)
    whines during normal accel/maintaining speed, hard accel doesn't affect it. turning makes it much, much louder...
    semi-relevant info:
    AC off (button, vents on floor only, not defrost)
    radio was off after I first heard it
    defrost/fogger off
    tried with both the fans on and off, still made the noise (so its not a volt spike, afaik)
    car was warmed up at the time (gear oil and engine oil, coolant obv).
    thoughts? :ugh:
    my guesses - belts, power steering (needs more fluid?...doesn't explain accel tho), front CV's (but its not clicking...?), radiator fans turning on (and complaining from the cold?)
  2. Yang
    Yang Well-Known Member
    mpls
    I would guess power steering to. did you check that?
  3. ArcticWolf
    Moorhead, MN
    negative, too dark (lol 2.5i, no light under the hood) and I don't have the garage tonight... will have to check it tomorrow / monday
    ...come to think of it, it probably is, because that would explain why the steering randomly gets heavier every now and again while I'm cruising around (I know it shuts off over a certain mph so its harder to spin, but I rather doubt that is set to 30-35). Definetly have to check that.
  4. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    this IS your power steering.
  5. curly2k3
    Silent Hill, Jackass
    power steering, mine was doing that
  6. ArcticWolf
    Moorhead, MN
    Is it normal operation, or ... ?
    I checked the fluid level, car was cold (had been sitting all morning 6am-1pm), fluid level was right at the cold max line on the res. so that shouldn't be it, I'd think. I realize I worded it poorly in the original post, didn't put a "?" after "needs more fluid".
    I also went out and tested for it again just a bit ago, it only did it once (while turning, accel whine was not present), vs just about all the time (last night). only difference (same route, same etc. etc.) was ambient temp. last night was ~10F, this was more like 30F.
  7. 02blubru
    Norwood Young America
    I used to have a whining under acceleration when I first got my car, but beth got used to the boos.
  8. ArcticWolf
    Moorhead, MN
    it's not a turbo'd car, though. otherwise I'd be happier than hell about it ;)
  9. 02blubru
    I know my post was pointless, just going for some humor...
  10. TSTRBOY2004
    was that the noise of the old people booing as you drove past or the ghosts of christmas past ???
  11. Chux
    Independence, MN
    so you have enough fluid.....but what color is it? it should be pink. mine makes noise, but the pump is failing, so the fluid is pretty dark.
  12. ArcticWolf
    Moorhead, MN
    ...yea, it was looking pretty dark. brown/blueish. I'll go snap a picture of it just for clarity (or second opinion, either or).
    EDIT: took the pic with the flash, was washed the hell out... toned that down in photoshop and the blue became glaringly obvious.
    So... not fluid, not pump going bad...? :eek3:
    EDIT2: went out for another drive.... RPM dependent, not gear dependent... seems to fade from 3rd on up (doppler effect + other noises getting louder - wind, intake, etc. - is my guess as to why). Does it in neutral as well as in gear.... and since I mentioned it earlier, ambient temp is again 30F (snowing this time, didn't really get to test the turning part for obvious reasons)... and its definetly quieter than the 10F one.
    Guessing its just normal, and I'm just paranoid at this point. :ugh:
  13. HoLsTeR
    HoLsTeR Well-Known Member
    its totally your pump. mine did that and then the pump went out....its nota biggie. just go to a napa or somthing like that and have them get you a new pump. i still havent gotten a new pump but its not really bothering me anyways. i dont mind not having my power stearing it just makes you buff!
  14. ArcticWolf
    Moorhead, MN
    Oil change soon anyway, guess I know who's doing it (and checking the pump under warranty...) now. As much as I don't want to set foot in their service dept. again.
  15. Chux
    Independence, MN
    yes, it is fluid. Subarus CANNOT run power steering fluid in their power steering systems. they use Dexron III ATF (auto tranny fluid). don't ask me why.....but that's your problem. running power steering fluid will destroy the pump (as proved here, and on my dad's '94 legacy).
    go get a long (~2 foot) piece of 1/2" inner diameter rubber hose
    a new pump
    a few quarts of ATF
    and a buddy
    -with the engine off
    -disconnect the small rubber piece on the return line near the pump. and only disconnect the end farthest from the pump (I hope that made sense).
    -use a bolt or something to plug that hose and replace the clamp to keep it somewhat sealed
    -attach the long piece to the metal line coming up from the steering rack where the smaller piece was just attached
    -drop the end of the long hose in an empty container of somesort (milk jug, bucket, whatever).
    -have your buddy start the car (make sure your bucket, lines, tools are clear of any moving parts!)
    -let it run until the flow into your container slows a bunch
    -then pour fresh ATF into the reservoir. don't need to fill it, just enough to give it something to pump
    -once it starts coming out the same color as it's going in, have your buddy slowly turn the steering wheel all the way one way, and all the way back a couple times.
    -then turn off the car, replace the pump as normal.
    this will help get as much of the baaaad fluid out of the system before putting your new pump on.
    also, I'd recommend doing this ASAP before the PS fluid damages the steering rack.
    out of curiosity.....what car do you have. you say 2.5i....so I'm assuming within the last few years. anyone know if they've changed the design to use PS fluid? I'll check my FSMs
    EDIT: the '02 impreza FSM still has Dexron III listed.
  16. ArcticWolf
    Moorhead, MN
    2006 imp 2.5i, its still Dexron III (according to the cap)
    Wonder if they'll take a warranty claim on it - front end was rebuilt after previous owner hit a deer with it, so they are (most likely) the ones who put the PS fluid in it. I (personally) haven't touched any of the fluids since I bought it, just the dealer (regular oil changes, etc.)... who pissed me off last time, so I was going to start doing it myself this time around.
  17. Chux
    Independence, MN
    ok, yea....Dexron is pink. So I'd be shaking my freakin finger at whoever did that!
  18. driftin240
    driftin240 Well-Known Member
    Out West
    Dexron III is a dark pink, almost red. Subaru has since released a tech note that says anything 2006MY+ should have ATF-HP in it. That fluid is still red in color, but it is a synthetic based ATF.
  19. ArcticWolf
    Moorhead, MN
    Yeah... mom'n'pop fix it shop up in bemidji, *shakes fist* :mad: Wasn't the subie dealer who tarded on the fluids, and it wasn't me... guess I'll call the dealer tomorrow and see if they'd do it as warranty or not. :|
  20. ArcticWolf
    Moorhead, MN
    follow up: dragged it into the dealer, they couldn't find anything... and apparently the fluid (was) red, but now its just dirty as hell...
    ...so either all of their techs are deaf, or I'm paranoid. probably a little of both.
  21. dman
    dman New Member
    Maybe doppler effect didn't let them diagnose it right ;)
    If you don't hear it with stereo on - then ignore it until it gets louder.
  22. ArcticWolf
    Moorhead, MN
    The first tech they sent out to test drive admitted he was partially deaf :p
