Who stocks NGK Iridium plugs for the WRX?
Discussion in 'Modifications And Maintenance' started by WagonsRock, Mar 13, 2007.
  1. WagonsRock
    WagonsRock Well-Known Member
    I want to pick up a set on NGK iridium plugs, one step colder, for a build this weekend. Anybody know where I can get them localy without having to order them in?
    Part number: 2667 (BKR7EIX)
    Thanks in advance.
  2. Musashi
    I have a set with less than 100miles if your interested.
  3. Justin
    Justin Well-Known Member
    and i have some with about 2k on them.
  4. stoooo
    stoooo Well-Known Member
    NAPA stocks NGK plugs. Give them a call and see if they have them in stock. I had to get odd ones (JIS v ISO) for my 2001 RS because I've got Magnecor wires. The EP NAPA had a whole boxful in the back.
    Stuart.
  5. Shibbs
    +1 for any big Napa. AAP may have them, but eh.
  6. WagonsRock
    Why did you take them off so quick?
  7. wings_23
    wings_23 New Member
    Do these come stock on a STi, if not, do they make a noticeable difference
  8. readymix
    Justin, I think I'm going to need those plugs back from you.
  9. readymix
    And no, Napa does not carry BKR7EIX.
  10. Rexwagon
    Rexwagon Well-Known Member
    fastwrx.com
  11. readymix
    Anthony at Boostkits.com sold me mine. He usually stocks them too.
  12. pbedroske
    pbedroske Well-Known Member
    Oakos.com - Dave is the best, I recommend them for anything they stock.
  13. WagonsRock
    I can find them all over the internet, that's easy. I am looking for local places I can just pick them up from.
    I think I can answer the STI question also, correct me if I'm wrong. First, the STI does not come with these plugs. Second, the plugs aren't going to help you unless you get a custom tune geared toward those plugs. Because they are colder, you can better avoid pre-ignition and detonation when tuning the engine.
  14. readymix
    Third, I don't think those plugs fit the STi heads either.
  15. AWDimprezaL
    the sti uses the same plug as the new style 6 cyl
  16. Musashi
    Got the incorrect ones for STI. LOL
  17. WagonsRock
    Ok, so the NGK's are looking fewer and farther between than I had hoped for. Are there any other options for me right now? Possibly a different plug that will perform the same?
  18. AWDimprezaL
    a copper plug will provide more spark, it just wont last very long
  19. WagonsRock
    Called NAPA today. The guy I talked to said the nearest ones would either come from NGK directly or from LA.
    I think I am just going to use the stock plugs for a bit. I have to break in the turbo anyways and I won't have a solid map for a while. I'll be limping around on a safe map for probably all of next week. :-(
  20. silver03
    plugs
    BKR7EIX..if you got these, I'm interested. How much?
