Why is a catch can important?
Discussion in 'Modifications And Maintenance' started by bikerboy, Apr 14, 2005.
  1. bikerboy
    I have spoken in the past about the importance of having a catch can installed in you car. Now I have some good pics to show you why it is important.
    Here is a pic of the I/C note the oil in the inlet.
    Here are pics of the inducer look at the film of oil!:
    With the quick whip of a paper towel
    I know a few of you have catch cans on your cars some of them even installed by me :D. I spent many hours this winter working on my car to make sure I did not have any more oil issues in the intake system. I have been testing my new system for the past month with great results. For those of you who have had a catch can installed by me I would like to see the car again to do the new modifications to stop this from happening. Or if you would like me to install one for you to prevent this I will gladly do so.
    Matt
  2. RallyNavvie
    RallyNavvie Well-Known Member
    This is for cars with breather systems, right?
  3. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by RallyNavvie
    All cars have crank case breathers and or valve cover breathers. Newer cars have to plumb this vapor back to the intake system as part of emissions rules. It is a particular issue on forced induction cars as there is always blow-by into the crankcase. This blow-by has to leave the inside of the motor, unfortuniately it carries suspended particals of oil with it. Since in the stock form it is plumbed back to the intake system the suspended oil is deposited in the turbo inlet hose hence the inducer pics.
  4. Musashi
    Great pictures, thanks for pointing out this problem and re-enforcing the importance of a Oil Catch can............Now where do we sign up?
    Are you taking orders, cuz I would like to place an order for two!
  5. Grimm
    Grimm New Member
  6. Justin
    Justin Well-Known Member
    Matt Spec Oil Catch Can.
    You still remember i wanted two right.
  7. bikerboy
    Sounds like I need to make some cans soon. I will be out of town next week so I will get some going when I get back.
    As a note I have to look at the WRX to see how I can do it on them as thet are different on the STI.
  8. Gspot
    Gspot New Member
    You can look at mine. I've been wanting to get one anyway. Also, any intere$t in doing a timing belt this summer?
    Kyle
  9. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Gspot
    Kyle
    Absolutely I will help you out. Get the parts and we will get it done.
  10. Dynapar
    Is this oil catch can setup the same as the one that was posted up using a air compressor filter? also how much do you want for the catch can setup?
    Thanks
  11. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Dynapar
    Thanks
    Nope it is much larger. I think I will be looking at 25.00 per can
  12. tbone
    tbone Well-Known Member
    Perhaps I'm going for Fong's Cappuccino DIY oil catch can setup from Menards materials.
  13. Grimm
    Grimm New Member
    When do you think you will be doing them. I have the parts for doing the pnumatic air filter version of it.
  14. Dynapar
    can you post up a pic of one, so i can see what it looks like.
  15. RallyNavvie
    I have a lot of breather plumbing down between the intake runners, IC, turbo, and intake. One is the reflux from the BOV I know, the other must be where the oil would come from I'm assuming. I've already got some sort of filter element on the breather assembly so I'm guess that does the same thing? It was part of the original Minnam kits. Last time I had to take the IC and turbo off it was pretty spotless for oil.
    I was planning on getting rid of all that completely since I can vent to atmosphere on the BOV without any adverse affects but had to come up with something for the other part. Are you talking about a catch that doesn't dump back into the intake?
  16. Gspot
    Gspot New Member
    catch can meet at matt's?
  17. AspitFire
    you can put me down for a catch can. Let me know when you are going to have them.
  18. MCJT
    MCJT Well-Known Member
    Wow, glad thats not mine!
    :I
    Yep, as you can see I sure need one. Sign me up.
    These were from when Matt ported my wastegate. Once again, great work. He even cleaned the heck out of my dirty engine bay!
    JT
  19. RallyNavvie
    So where is the plumbing on the block where this is coming from? I took a look in that jungle of hoses I've got there and couldn't tell which was which. I'm going to be putting the car up this week to do some compression tests on the coolant system (I still have a small leak I smell somewhere) and do some other spring tuning things so I'd like to see where I could put one in.
  20. Grimm
    Grimm New Member
    So I have been looking at catch cans and I was thinking that the water seperator for pnumatics wouldn't nessisarily get enough out, so I was wondering if you used baffeling material in your design matt?
  21. RexN
    RexN Well-Known Member
  22. Grimm
    Grimm New Member
    little bump now that matt is back
  23. bikerboy
    I am not sure on a RS I would need to look at it.
  24. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Grimm
    Foam filter separates the in-bound from the out-bound
  25. bikerboy
    I have 2 STI catch cans done.
    50.00 with all hoses, fittings.
    I dont really recommend self install with my kit as it requires re-routing many hoses and pluging where they use to go.
  26. Speedemon
    Speedemon Well-Known Member
    Would it be the same price for a wrx
  27. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Speedemon
    I have to look over the WRX again to see how to modify my solution for the STI to the WRX. Stay tuned.
  28. Grimm
    Grimm New Member
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by bikerboy
    Once I get the NSX back you can use mine as a test bed if needed. :D
  29. bikerboy
    Roger!
  30. Gspot
    Gspot New Member
    I lost my job, so I'm free on weekends now. If you want to test fit.
    I assume the can itself is mounted somewhere? We had an issue in tech inspection with a WRX at the last autocross that had it loose. I think he ziptied it or something.
  31. RexN
    Matt, when are you available to do the install?
  32. scoobydreamin
    scoobydreamin Well-Known Member
    I am interested in one, the tough will be scheduling a time. PM me if you have one available and we will figure something out.
