Why you should choose Fuelab for your next fuel system upgrade!
Discussion in 'Vendor Announcements/Sales/Discounts' started by maperformance, Sep 22, 2007.
  1. maperformance
    maperformance Vendor
    Reason #1: It works!
    Reason #2: It costs less!
    We've made 700+whp on our budget Talon with Fuelab products! And we're not alone, check out the AMS Evo for yet another example of how well these products work!
    Fuelab Adjustbale Fuel Pressure Regulator $149.99 (See below for a MNSubaru only discount)
    FUELAB™ Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference.
    All FUELAB™ Fuel Pressure Regulators Feature:
    - Precision pressure adjustment hardware
    - 1/8" NPT gauge port (for external pressure gauge, plug supplied)
    - 1/8" NPT pressure reference port with supplied barbed fitting
    - -6AN return line port
    * Select from standard bottom positioning of the return port or inline positioning for tight installs.
    - All stainless steel hardware
    - Versatile bracket included
    - Long life fluorosilicone diaphragm
    - Fuel fittings sold separately
    *These particular regulators are designed for EFI applications running between 25-90 psi BASE fuel pressure.
    818 Series In-Line Fuelab Filters (3" Length) $89.99 (See below for a MNSubaru only discount)
    FUELAB™ In-Line Fuel Filters keep your engine running clean. They require no additional AN union or reduction fittings and feature machined internal radii for minimal pressure drop. The 818 Series Fuel Filter is equipped with a short (3 inch) filter element.
    All FUELAB™ 818 Series Fuel Filters Feature:
    * -6AN, -8AN, -10AN or -12AN male inlets or outlets
    * Low profile saddle clamp mounting bracket(s)
    * 200 PSIG maximum pressure rating
    * Replaceable or cleanable filter element
    Available Filter Elements:
    10 Micron Cellulose (Paper) - This element is the most common style in use. Provides excellent filtration and compatible with most fuels (Gasoline, Diesel and Alcohol). This economical element is disposable and not recommended for cleaning.
    40 Micron Stainless Steel - This classic style of element was born where harsh conditions and ultimate fuel compatibility was required. Element is cleanable and does not necessarily require replacement for maintenance.
    75 Micron Stainless Steel - This cleanable element is well suited as pre-filters for fuel pumps. With extremely low pressure drop, this element helps prevent pump cavitation. Micron rating suitable to protect pump only, finer micron rating is recommended to protect injectors and carburetors (downstream of fuel pump).
    828 Series In-Line Fuelab Filters (5" Length) $106.99 (See below for a MNSubaru only discount)
    FUELAB™ In-Line Fuel Filters keep your engine running clean. They require no additional AN union or reduction fittings and feature machined internal radii for minimal pressure drop. The 828 Series Fuel Filter is equipped with a longer (5 inch) filter element which allows for greater flow capacity and increased filtration.
    All FUELAB™ 828 Series Fuel Filters Feature:
    Plus!
    * Long style (5 inch) filter element
    * Less pressure drop (works great as a pre-filter)
    * Greater flow capacity
    * Increased filtration capacity
    * Reduced maintenance frequency
    Available Filter Elements: Same as above.
    Ready to make a purchase? We are now offering 10% off all Fuelab products until October 21, 2007! Simply follow the link below and enter the discount code "fuelab" without the quotations in your shopping cart to receive the discount!
    http://www.maperformance.com/store/manufacturers.php?manufacturerid=141
