Winter mods
Discussion in 'Modifications And Maintenance' started by WRX1, Jan 1, 2004.
  1. WRX1
    Just wondering hwat everyone has going on this winter to their car?? I know on NASIOC Joel was getting a little upset because nobay what share any mods, so for you Joel, this is what I have going on!
    www.freebmw.net/don/nasioc/wagon.jpg
  2. Zola
    Zola Well-Known Member
    LOL...
    You people can have your secrets, they can't stay that way forever. Come spring you'll have to show us all the goods. I would like to work on checking/fixing my fuel trims...so if anyone has one of those handy OBDII loggers I could borrow, let me know.
  3. Scooby02
    Scooby02 Well-Known Member
    Hey howd you get a pic of my new project install? I thought the car was in a restricted area. oh well guess the secret is out. :p
  4. WRX1
    Joel, give me a call. I will let ya borrow my scan tool cable and software if ya want. It just shows obd-II stuff, so I'm not to sure about fuel trims and such. I will dig into it a bit and see whats in there.
  5. Todd
    Todd The Originator Staff Member
    Even generic OBDII will give a LTFT (long trem fuel trim) and STFT (short term fuel trim).
  6. kickin_81
    kickin_81 Well-Known Member
    Looks like a stage 18. That's awesome! :eek::mrgreen:
  7. WRX1
    Yep, it is in there. I have never looked for the fuel trim stuff, so I wasn't quite sure if it was there or not. Let me know. I can burn the software to disk and let ya borrow the cable if you want.
  8. bikerboy
  9. Chin
    Chin Well-Known Member
    Well, I am spending a little time with the RS... I have a new single stage brake booster/cylinder sitting in the garage, waiting to go in. I will have new, custom valved/sprung, JIC FLT2A-RS coilovers in before spring. Let's see, what else... Hmmm, if taxes are nice to me this year I may have a 6psi turbo running on it as well, sometime early this summer. Todd, when you getting that dyno in? }:) Oh, I have to replace my belt, too, it started to shred last time I drove it. Well, not too much interesting for most of you in your WRXs, but just wait until you see me out at the track!
  10. RallyNavvie
    RallyNavvie Well-Known Member
    I'm just waiting on a dyno, though I may show up to the shop to get that intake taken care of. I may have posted some secret information on my next mod at some other forum...
  11. PHATsuby
    PHATsuby Well-Known Member
    im letting my car sit for 5 months so it can figure out its problems and tune itself, so when i get back it will ultimate!
    LOL
    Ben
  12. Zola
    Well, Russ and I got my fuel trims in order (at least at idle). I threw a CEL not even two blocks from his house, but by the time I got to Autozone in St Paul it cleared itself and their scanner showed no codes.
    It's been a long time since I reset my ECU, so I don't remember the relearning process. The car is surging a bit under boost...no knock at least. I was fiddling with my timing in the 3000-3500 range but I didn't change anything too drastically. Maybe everything will smooth out in a day or two once the car figures out an IAM to settle on.
  13. WRX1
    Try doing the Vishnu reset (sorry don't remember the specifics), but that is supposed to get the ecu back to its highest correction factor on the low det map. If I find it I will post it.
  14. igofast
    igofast New Member
    Vishnu Reset(from what I can recall off the top of my head): After reconnecting the negative terminal, get car in 3rd gear and hold boost at 7psi for ~10 secs.
  15. Zola
    Well I didn't need to do the Vishnu reset, I just needed to slap myself around a little. Somehow I contrived a way to fill a couple cells in my fuel map with 4.4 when it should be -4.4 (haha)...so it was outrageously rich in that spot.
    All better now. :eek:)
  16. WRX1
    woops. I guess with the vishnu reset it will put you in the low det map with the timing maxed (no retard anywhere). I will have to look for it on nasioc.
  17. Substeroo
    Substeroo Well-Known Member
    So you guys can call me lame but I shaved my back hatch of all emblems and put on a new mesh grille in the front. No power mods though been broke and busy with other things. (i.e. caring 4 pregnant wife and now baby!) :D I'm going to take off my crappy tint job this spring and put on lighter, prob 50% all around. I think it looks nicer. Not sure yet but the thought of doing an engine swap is upon me right now. :)
  18. DISCOPOPE
    DISCOPOPE Well-Known Member
    <center>fyi here is the shiv reset
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">ust a little trick that has been shown to accelerate the factory ECU's ignition timing learning process.
    Background: There is something called "Ignition Advance Multiplier". It represents, by some complicated algorithm, the average learned positive knock correction applied to the ignition maps. It's represented in 1/8th degrees increments. 1 being the lowest and 16 being the highest (1/8 to 2 degrees in absolute terms).
    The "happier" (knock free) the car is, the higher the number will be. Conversely, the lower it is, the more knock prone it is. This number, after ECU reset ore ECU swap defaults to 8 and usually creeps up to 16 (if well mapped) through normal driving. Depending on driving characteristics, this can happen within a few hours or a few weeks. Well, here's a way to make it happen in about 5 seconds ....
    First: With the car fully warmed up, reset the ECU. This can be done by killing power the ECU or by simply pulling off the neg. battery terminal and pressing the brake pedal for a couple of seconds.
    Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower
    In an attempt to save a lot of dyno time between reflashes (when the advance multiplier resets itself), I do this little trick after every reflash. In a typical dyno session, it's not unusual to reflash the same car up to 5 times. On the dyno, all I need to do is tell the dyno to hold revs to 2600rpm. Then I just lay on the throttle until I see a few psi of boost... Bingo!
    Warning: This little trick artificially speeds up the learning process. This is only a good thing if the re-mapped ECU is mapped properly. If there are trouble-spots where knock is present, this trick will make it even more present. So be careful!
    Cheers,
    shiv
    www.vishnutuning.com
    <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"></center>
  19. WRX1
    Cool, I was going to post that once I did a copy/paste, but looks like you beat me to it. Thanks for the update.
  20. Gspot
    Gspot New Member
    I modified the front end...
  21. jprice
    jprice Well-Known Member
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Gspot
    Allow more air to future FMIC? ;)
    Sorry to see that.. is it fixed up?
  22. Gspot
    Gspot New Member
    beginning of next week it should be ready
  23. WRX1
    I think I would have come up with a bit easier way to put in the lightweight jdm bump beam.;)
  24. Gspot
    Gspot New Member
    easier...no cheaper...yes
    I wonder how the jdm beam would have faired...
  25. bikerboy
    whose car is that? I hope it is not my old one?
    M
  26. WRX1
    So Matt, you going to leave some wrx injectors for other people to mess around with??;)
  27. Gspot
    Gspot New Member
    Matt thats my car.
  28. bikerboy
    Matt thats my car.
    Where and when did you get it? Someone on the board bought my old car and I thought it was you?
    M
  29. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by WRX1
    You have injectors, dont you?
  30. Zola
    I'm just realizing the direction this could be taking...so Matt, if you end up not using the injectors I gave you, I'm not really interested in taking them back in a modified state. So if you try to turn them into 700cc's and screw it up, that isn't free. :D
  31. yosmiley
    No mods for me this winter but when Spring time comes... I'm setting myself for some suspension tunning, as Matt and I have discussed earlier. Gonna find some time to do an oil catch can as well... been talking about it but haven't got the time to get with any of you guys for this.
    No power mods for me for another year. I'm gonna wait and see what works and doesn't work before I jump into the power wagon.
    I don't consider adding gauges as mod... as I just got my Defi pod and gauges ordered. Once it gets here... I'll need Matt, Russ or someone whose had experience in this field to help me out with the installation. Payment will be pizza and beer... unless we hit up Perkins or Culvers, etc...
  32. Zola
    Heheh...I'll do gauges for pizza. That's some good incentive.
  33. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Zola
    :eek: me screw something up? I am truely offended! If you would like your money I can certainly give it to you. Your call!
    M
  34. WRX1
    I tried to get Daves injectors, and Matt already has them! I guess its time to start surfin' e-bay.
  35. Gspot
    Gspot New Member
    I got the car in July from a guy in Prior Lake.
  36. yosmiley
    I did a cheap mod this past weekend... I got an oil catch can, with Matt and John's help that is. Thanks guys!
    I can't wait till Spring so I can get the other project underway. Beside... I'm still looking for a daily driver so I can park this one and start taking things apart... like someone on this board, LOL!
  37. WRX1
    What Catch can did you install?? That is going to be one of my other cheap mods I need to accomplish this winter.
  38. yosmiley
    Russ, since you've already seen my oil catch can... let's head on out to get the item needed to make you one?
  39. WRX1
    Sounds good. Just let me know when. I'm not in any hurry anyways. Maybe we will just have to build out a couple of them and sell them on E-bay.
  40. bikerboy
    Hey boys don't steal my design and sell it! That is not fair!
  41. yosmiley
    Matt... You didn't hear that from me :D Maybe you and Russ can work out something about making money from your design.
    Matt, check your schedule and see if you'll be available in the late morning. I'd like to swing by to pick up the valves we bought from Home Depot and return it. I'm going to exchange it for other parts to make an Oil Catch Can for my brother's EVO and WRX.
  42. WRX1
    Don't worry Matt, we will give ya 1%.;) Now if I could find a cheap set of wrx injectors.....
  43. bikerboy
    If you need one let me know I will make one up for you
  44. WRX1
    I'm in no real hurry now. Once it gets closer to spring time I will probably do it. I just have to get some of my small projects going so once it warms up I can work on the big stuff.
