are EL headers worth it on our cars? as far as power gains with a new turbo, will you see a big difference in numbers when it comes to tuning? reason i'm asking is i just put one on my car and the sounds is, well, less than satisfactory. I dont mind it that much but then whenever i see a wrx roll by with an exhaust i miss how my car used to sound. its like night and day. should i stick with these or sell'm and keep the stockers?
They can help with spool, at the expense of the rumble. It all depends on what you want outta the car. Are those couple hundres rpm worth it? You are the only one who can answer that. If you look at the exhaust(heat) pulses hitting the turbo with a stock manifold, they look like this .. .. .. .. .. .. .. .. .. .. .. .. .. .. With an EL manifold, they look like this . . . . . . . . . . . . . . . . . . . . . . . . . . . Thats why gains can be had with an EL setup. A twin scroll setup amplifies this even more. But as I said, it's all about what you wont out of the car. (thank fobia for the diagram )
Keep them if you want more performance. Sell them if you just want to sound good. It's the unfortunate trade off with EL headers on a Subaru.
Seen this? http://www.iwsti.com/forums/showthread.php?t=91701 this, too. http://www.iwsti.com/forums/showthread.php?t=91173
dont use stockers, trade them for aftermarket un-equals, or just keep them, your car sounds mean as ****, its different, but thats what is cool....everyone knows the suby rumble...but when an sti comes up and sounds like that.........its evil---get a new turbo and injectors and a tune and you will be set to jet KEEP YOUR HEADER..r u coming out tonight?
So I take it you already have a bigger pump and injectors?? If not, you are wasting your money. You don't have enough gas to properly support stg2, much less stg2 with mods (ic, header, pnp anything). Look up Mlgez's thread about the upgrade path he did with his STi. Russ
At least for an STi you do if you dont want to be at 95% IDC. And if you are doing ANYTHING else to car you do need them.
You have to taper off boost a lot at high RPM with a normal stage 2 car because you run out of injector headroom. So when he says "Properly support stage 2", he means that more power can be had with bigger injectors because you can hold onto your boost longer.
already have 850cc injectors and a walboro in my room. waiting for the turbo to come and then i'll put them all in at once. I'm well aware that my IDC is probobly very high right now. I didnt expect to see any gains just bolting them on but i was absolutly amazed at how much smoother the car feels. just getting into gear and playing around with the throttle, it feels much better. the only thing i miss is the growl
if you keep a resonator in the midpipe, the EL sound is very nice. mine sounded like **** on my borla, catback.... like absolute ****... i switched to a perrin cat back and it's the sex. kind of a cross between an evo and a 911.
oh i know, it sounds kinda average when its down low but when you get up into higher rpms, she screeeaaams
Boost tappers on it's own at high rpms with the vf39. I'm running just as much power as a stage 2 STI with almost 19lbs peek and IDC's are never above 91%.. that's with a rather rich a/f ratio. Seach IWSTI and you'll see everyone else saying the same thing. Pump and injectors aren't needed for just S2. A pump good to have? At 80 bones maybe. Injectors, no way.
Well, with the 15-20 sti's that I have tuned, all of them have maxed out the injectors around 5000rpm. I have yet to not max out the injectors on a 2.0 or 2.5 stage 2 car. That is with a afr of 11-11.3:1. Read this. http://www.mnsubaru.com/forums/showthread.php?t=16952 Russ
I have and I think most would agree that using DB as a reference thread on tuned cars is a laugh. Nothing against mlgez for going there but that was a lot of hoops to jump and a lot of parts to get 280hp. They obviously are missing a few things. Not sure what to tell you about your 15-20 tunes. Every thread on IWSTI I've seen re: injectors and S2 say it's not needed. My logs say the exect same thing. Heck, stock my IDC were 5-7 % higher then what they are tuned.
Dynos are reference tools. RS I am sure this would read more. It is not about the overall number but going to the same dyno each time to get an idea of how much change you had and if the mods help. As for 280 on a VF-39, stage 2s there all put down 250-260 consistantly. So exactly how is it a laugh? Everyone should know dyno to dyno there will always be differences, even of the same manuf...
Oh and from the readings I have done the desired duty cycle is 80-85%. After that the injectors start to not be able to open and close fast enough. They can only open/close part way from full close/open when you are asking them to turn on/off and then back off/on too fast. There is a ramp up/down time. In electronics it is called rise and fall time. Above that 85% time they can not open and close fully. Everything I have heard or read says you hit that above 85%.
Your logs are showing 90% idcs at only 14 psi. wtf do you think is going to happen when you get an actual exhaust that will allow the engine to pump some decent air and also bump up your boost to 16-17psi @ redline?
Go up? sure. Enough to warrant new injectors *just* for that? No way. Not on the stock snail and/or pump gas.
I am not going to get in a pissing match with ya. But if you think that running 14psi is ok, then have fun. I would consider that log to be less than a cobb ots map. There are a bunch of little things that you could do to pick up some power and spoolup, but I guess we are not here for that. I will stick by my previouse statement. If you want to maximize you parts, bigger injectors are needed. If you just want to run 13-14 psi, keep it stock. Russ
You say that like you can run 20psi to redline with the stock snail at S2 levels. Good luck with that. Almost everyone at that level tappers back down to stock at redline. It's just the way it is. I'd like to see one example of an S2 OTS map that puts boost higher then 18psi peek. I've yet to see it and most report 17-18. As for being happy or not where I am, I'm good. I'd like to see a log/dyno plot of what you'd call good though.
Like I said, if you want to MAXIMIZE what you have. I would not bolt headers onto a car that is already short on fuel. A simple stg2 car will max out the injectors. the idea of custom tunes is to maximize the parts you have. If you are ok with a tune that just gets you by, thats your call. I myself want all my parts to work together and I want to maximize what I have. Kinda silly to bolt on a tbe and headers and not put a good tune on it. Russ
Well I was able to move up 2psi at the top end because of larger injectors. Yes the factory turbo tapers off but you have to taper off faster because of the injectors.
Not sure what to tell you. All day long I can pull out posts of people running 21 psi tappering down to 17 on stock injectors tuned by people like PDX and XX. Yes, they upgraded the pump. No they didn't upgrade the injectors. That's pump gas and no meth. That's also with a few supporting mods beyond a typical stage 2.
Sorry for the old bump but this exact question just came up on IWSTI (Does stage 2 need injectors for ANY reason?). Just wanted to point the thread out to others. http://www.iwsti.com/forums/showthread.php?t=92719 Notice post #6.
I guess if you want to run over 100% idc's, go for it. Like I have said the whole time, if you want to MAXIMIZE what you have. You would never be able to support the power the mlgez has with stock injectors. It just can't happen. Can you tune a stg2 car to run safe with stock injectors. Sure you can. Now, will you get alot more power out of the motor when you can SAFELY support more boost?? Hell ya. Russ
They proved that exact statement wrong in that very thread and the other linked within it. The VF39 at Stg 2 levels simply cannot flow enough to max out the stock fuel system, period. Adding a pump and/or injectors will net you nothing but lower IDCs. They also addressed safety and the tuners in there all agreed that holding the car at 11.1 or richer was not an issue. As for DB and their tuning of mlgez goes, to each their own. That's all I got to say about that.
Actually the tune is Russ' with DB tweeking the levels a little in the areas that needed it with new mods. Russ was moving and could nto get to it. The AFRs are great and the timing has not been touched.
