Wrx braking
Discussion in 'Modifications And Maintenance' started by wrxjoe, Jan 19, 2007.
  1. wrxjoe
    wrxjoe Well-Known Member
    I am just wondering how much brake fluid I need for my car. I am putting new rotors, pads and lines in. Also, is anyone running stoptech's stage 2? opinions?. What is a good set of stainless lines to go with?
  2. bummpy
    bummpy New Member
    ss lines?
    probably the brand that fit. I don't think any of the brands actually manufacture the flex tube they use to build (ie, they probably all use the same source).
    I don't know, someone correct if I'm wrong.
    Otherwise, BF Goodrich seems to be a normal go to brand.
  3. ShortytheFirefighter
    BF Goodrich is the tire company, Goodridge is the brake line manufacturer. I have a set on my car, they work very well indeed. You'll need 2 pts of brake fluid but you won't use all of it. Another option is to do the Legacy rear brake brackets/rotors, which give you an inch bigger rotor in the rear. Better than OEM pads will make a difference as well. For fluids, I've been running the ATE Superblue/Typ 200 combo, same fluid just different color so you can see when you're flushing the lines when you've got them changed out.
  4. WRX1
    Well, it will take less than a pint of fluid for a flush. Every subie that I have done I usually use the full pint, but the last rotation around the car is pretty much just a waste of fluid at that point. You can also talk to Mark at Diversified, his ss lines are going for $108.
