Everything is off my 2002 Wrx sedan (unless stated) so fitment is determined by you. Feel free to call or text 763-923-1616 (ill text pics of anything you want) ~Ultimate Racing 850cc injectors $100.00 (injectors only) ~02 WRX heads $250.00 (No valve covers, cams or valves) ~HKS turbo timer with wrx harness $15.00 ~02 WRX smoked taillights with WRB covers $40.00 ~02 WRX oil pan and dipstick $20.00 ~Crucial Racing 160 degree thermostat $35.00 (almost new) ~Samco blue upper rad hose $15.00 (wear mark from alt. pulley but still holds coolant) ~04-05 sti bezal around radio and center vents w/ cupholder $25.00 (perfect shape) ~stock exhaust manifold w/out uppipe $25.00
I can take the stock exhaust manifold. Is there any damage or modifications on them? Where are you located? Mike
yup, you'll need harnesses and the spacers for the fuel rails. I just got off the phone with Ultimate, he'll be calling me back with a price on everything you will need for a install. Miles would be somewhere around 5k to 8k.
I received my call from Ultimate racing today and the guy is very informative about injectors! First off they are NOT 850cc they are 785cc low impedance injectors so depending on your application you will need to run a resistor pack as i did on my 02 wrx. And depending on what fuel rails you are running will depend on what or if you will need the spacers. So with all that being said the price to get these to work in your car all depends on your setup. Either way they can easily get you what will be needed and for only $100 (OBO) should be a lot cheaper than buy'n new.
