WRX shakes when I shut the engine off?
Discussion in 'Modifications And Maintenance' started by Flexure, Apr 17, 2009.
  1. Flexure
    Flexure Member
    I have a 03 WRX (just bought it, so this is not an issue that just suddenly occured, it has always doen it), and when I shut the engine off it shakes. I have owned cars in the past that shaked when I shut the motor off, but the cars were always POS's, so I am wondering if this is "normal"? I am assuming that this is just either crappy stock motor mounts, or I infact have a bad motor mount? Any input appreciated.
    Oh, and one other thing, pretty sure it is unrelated, but when at idle, my factory boost gauge moves slightly, all other boosted cars I have owned in the past stay at a steady vacuum when at idle, but the wrx has what seems to be a slight vacuum leak perhaps, although the fluctuating boost gauge does NOT effect the rpm's. (rpm's do not bounce or surge at idle)... I have had one other reputable subie owner in my car, and he said that this was perfectly normal, I just wanted a 2nd opinion I guess, because I am uber paranoid about everything, haha...
  2. Subaru004
    Subaru004 Well-Known Member
    My 05 WRX shakes when you turn it off too so im pretty sure its normal
  3. esperunit
    esperunit Well-Known Member
    the gauge is a piece of crap and all gauges will move slightly, they just have averaging usually that keeps them more still.
  4. bobafett04wrx
    bobafett04wrx New Member
    I think the shaking thing is normal cuz my 04 does it too, prolly could fix that with some better mounts as you said.
  5. ej20
    ej20 Well-Known Member
    Yeap, the shaking is normal. My 02WRx does it too. I guess its b/c its a Boxer Engine?
    Somehow I like the shaking.
  6. KA-T_240
    KA-T_240 Well-Known Member
    i dont notice my car shakin when i turn it off. I get a random drop in rpms everyonce and a while at idle it acts like the car is shaking.
  7. stoooo
    stoooo Well-Known Member
    Well, I didn't have a WRX, but the engine in my 2.5RS would shake a bit at start up and shut off. Then we put GrpN motor mounts in it, and the first time I started it, it looked as though the car was going to flip itself on to its roof. That's how squidgy the stock motor mounts were.
    I think all engines have a tendency to shake somewhat at really low revs. Diesels are notorious for it.
    Stuart.
  8. qstarin
    qstarin Well-Known Member
    Also on an RS, mine shakes a bit when it hits like 600 rpm or when it shuts off completely. It seems completely fine and normal to me.
    When I put my group-N mounts in, nothing moved anymore - not at all - and the shake was vastly reduced. Sometimes it dies when I put the clutch in, and I don't even notice, where before I could always feel it shake when it shut down.
  9. 763WRX
    763WRX Well-Known Member
    It sure is normal. My 02 wrx, 04 wrx, 04 STI all shakes when i turn off the motor :)
  10. 1_sic_rex
    1_sic_rex Well-Known Member
    Get new mounts. Mine does the same it seemes to be the mounts.
  11. jinkm
    jinkm Active Member
    I've got an 03 and my engine shakes when I shut it off as well. Sometimes it shakes harder then others. Sometimes, I don't feel it at all.
  12. MBOUTBACK
    MBOUTBACK Active Member
    My OB shakes when idling at a stop light. Seems normal for all Subies. How hard is it to replace motor mounts?
  13. Scuba Steve
    as stated above...motor mounts motor mounts motor mounts.
  14. Kracka
    Kracka Member
    Definitely a motor mount if the shaking is excessive. As for your gauge, its just faster reacting than others. My Defi gauge moves very quickly and will also do this at idle.
