WRX vs Spec C Strut Difference
Discussion in 'Modifications And Maintenance' started by Justin, Mar 1, 2007.
  1. Justin
    Justin Well-Known Member
    I figured sense i had both of my suspension set ups off i'd take a pic of how much more wussy the wrx strut is.
    check this out!!
  2. Shane86
    Shane86 Well-Known Member
    That's just because it's an inverted strut design. if you were to remove the outer housing, you would still see a similarly sized shaft.
  3. Justin
    ok well then..i'm a moron.
    mods you can delete if you wish.
  4. piddster
    Inverted dampners are supposed to be more resistant to side loads compared to standard. Pretty much any serious coilovers that may see rally use will be that way.
  5. Ravyn
    Ravyn Well-Known Member
    No need to delete, I didn't know this!
  6. Justin
    so i actually went out and checked the whole strut out. i cant find a skinnier part that you guys are talking about.
  7. austinpike
    austinpike Well-Known Member
  8. Justin
    no, i'll give it a shot though
  9. austinpike
    If you look at the pdf, you can see it, you don't really need to take yours apart... I mean, unless you want to.
    afaik, the spec-Cs aren't really much different (if at all) than the stock USDM STi struts.
  10. piddster
    dammit!!!!!! just get the proper strut tops and slap'em in. question and answer period is over!!!!
    I had a great experience with Teague's (www.boxer4racing.com) Get a full set of group N's, and they'll set you up.
