Looking to add a slightly larger rear sway bar to my wagon, and apparently I can get the stock STi rear sway bar to fit if I mount it on the outside of the endlinks. Granted the effectiveness may be reduce a bit, it will still be an upgrade over my current one. Let me know if you have one that you want to get rid of for cheap. I'm willing to drive to pick it up. Thanks! Jordan
sent you a text... KAT240 - unfortunately won't be at BIR this weekend :-( Otherwise, aren't you located in Fargo or something? If it doesn't work out with eternity, I'll keep you in mind!
just discovered that the 02-03 WRX also came with a 20mm rear sway bar, which would mount up perfectly to my wagon (instead of putting the STi rear sway bar on the outside of my endlinks)...I would like one of those if possible! MODS: Can you update the title and first post to reflect that I'm looking for an 02-03 WRX Sedan 20mm rear sway bar OR the 04-07 STi 20mm rear sway bar?
Yes, I am located in Fargo. I'm always running around MN/ND and the ocasional Sioux Falls Trip so ya.
