WTB 04 sti throttle body / sensors / coilovers
Discussion in 'Want To Buy : Cars/Parts' started by Nater, Feb 15, 2012.
  1. Nater
    Nater Member
    St Joseph, MN
    looking into possibly getting coilovers, and needing a used throttle body / sensors possibly.
  2. Nuke
    Saint Paul
    contact felipe for the throttle body
  3. Nater
    Nater Member
    St Joseph, MN
    ya, I got to find out If I need to replace the sensors or the body, not sure if I should just replace them both or not.
  4. Nuke
    Saint Paul
    on the throttle body? lol...you'll need the whole throttle body itself
    get at felipe
  5. tangledupinblu
    Online
    MNBugeyeMafia#001
    You'd probably be all good buying new sensors unless the actual TB is damaged? I have a used throttle body, but you'r want a new IACV and the other air sensor. I feel like the IACV was like $117.00. Check at Napa/CarQuest...or Morries.
  6. phi11
    Action Valley
    If it is the throttle body, I have a few extra motor, but i bet it's the sensors.
  7. Nuke
    Saint Paul
    dbw throttle body are difference compare to dbc throttle body
  8. bikerboy
    on the water looking for the sandbox
    What is the issue with the throttle body?
  9. Nuke
    Saint Paul
    cel randomly pops up and throttle body goes to sleep lol.
    have to reset ecu
  10. bikerboy
    What cel?
  11. Nuke
    Saint Paul
    hopefully he can reply back
  12. Nater
    Nater Member
    St Joseph, MN
    The first time I was turning left, and i got no throttle response on the peddle, engine light shows up. I was only blocks away from my house when it happened the first time. Friend came to get the codes, the codes were two cam advance codes with two tps codes. It was reset and ran just fine. Monday morning things happened again, but the throttle is working now after I tried starting but I wasn't getting any response before.
    I'm going to get it read again but I'm waiting for my friend to come back over and rescan for what the code is again.
  13. bikerboy
    So A P0011 and P0021 those are the cam codes. Have you remove the banjo filters? Let me know what the TB codes are and I bet I can help you out with that as well.
  14. RichWRX
    RichWRX Well-Known Member
    Orr,Mn
    I have a tb from a 04 sti if you end up needing one.
