Looking for front and rear shock and spring setup. Stock or aftermarket. No Coilovers. PM or post with price and detail. Pictures too if you have them.
I keep moving through suspension. I'll keep moving until I find the right set. Originally had BC Coilovers: The stance is great. Ride totally sucks. Its bounces everywhere and the stiff setting is just too rough. They say adjustable but no matter what setting you're at, the rides still sucks. Then had Koni Yellow Adjustables with Rallitek springs: Love the stance and ride. Even the littlest setting, you could feel the difference in ride. But it was too low. Tires were tucked under fender. The outback tires always rubbed against the inner fender. Had jeff the alignment guy try to correct the problem but nothing he could do. Next step is to try legacy wagon suspension. Although I felt I should of just kept the Koni's and switch out my tires from 55 to 50 series. Then I would of had to do the same with my winter setup. I'm really cluesless at this point.
I was being a dork. unfortunately a new setup isn't in the works for me just yet. look around at legacygt.com , there should be some stuff there. Lots of part outs, and people upgrading. Hope that helps!
