wtb: 1.8 fuel rail
Discussion in 'For Sale : Car Parts' started by asiandude, Aug 28, 2006.
  1. asiandude
    asiandude Well-Known Member
    if anybody has a 1.8 fuel rail. just wondering is the phase 1 2.2 rail the same as the 1.8?
  2. AWDimprezaL
    Monticello.
    The rail should be the same
  3. Yang
    Yang Well-Known Member
    mpls
    upull has tons
  4. asiandude
    dao took the last one at upull
  5. 95lwrx
    95lwrx Well-Known Member
    brainerd
    i believe they are diff, there is supposed to be something about the 1.8 rails that you can fit in usdm sti injectors. and apparantly it's only the 1.8 rails that work, i have both sets of rails from a 1.8 and 2.2 so i will have to check and see how they differ. but i'm keeping mine for when i want to upgrade to larger injectors.
  6. 6MTizzle
    6MTizzle 2SLO
    South Side
    ^ yes, I believe that is his goal
  7. asiandude
    yes, that is what im trying to do. my injectors is at 95% with what im runnning right know.that is the reasom for the upgrade.
  8. Threshld1
    Threshld1 Well-Known Member
    SLP
    get yourself some BC/BF 2.2 N/A rails and they will fit the sidefeed sti yellows or pinks. SRT20DET sidefeeds also fit apparently. The turbo rails are cockeyed to the block whereas the N/A are strait.
    Ive got a set lying around untill i get some better injectors with the same thing in mind =).
    Make a post on legacycentral you should have no problem getting them for like $20 shipped. There are many posts there with plenty of info aswell
  9. FuJi K
    St. Paul, MN
    like said....LOTS OF Legacy NA's at UPULL.....maybe I should take them all....and sell them.
  10. piddster
    Boostonia
    Make shure you 92-94 N/A rails, as the 90-91 rails are different.
  11. AWDimprezaL
    Monticello.
    They show the same part number, so they should be the same.
  12. FuJi K
    St. Paul, MN
    yes, true that!
  13. piddster
    Boostonia
    Its the turbo rails that are different. Durr :roll:
