Wtb 215/35/zr18 tires
Discussion in 'Want To Buy : Cars/Parts' started by Sleeperwrx, May 28, 2013.
  1. Sleeperwrx
    Sleeperwrx Active Member
    I'm looking for a cheap set of 215/35/zr18 tires. Does anyone have or know where I can get cheap tires?
  2. readymix
    What car are they going on? If it is for your WRX, that isn't a good size to be running.
  3. readymix
    If you just want cheap tires, you can always search craigslist for used tires
  4. Sleeperwrx
    Yeah it's for my Wrx. How isn't it good?
  5. readymix
    Because the circumference of the tire is off by 3 and a half inches. Making the rolling circumference 4.2% too small. For an 18, you should be a 225/40/18 for a 7.5" wide.
  6. Sleeperwrx
    Oh ok. Cause the tires that came with the rims I got are 215. Well if that's the case I think I might know someone who has some. Thanks
  7. readymix
    215 is the section width, the aspect ratio determines the sidewall height, and thusly the rolling circumference. You could probably run a 215/40/18, but the 35 aspect ratio makes the sidewall too short for that tire.
  8. Sleeperwrx
    But if the sidewall 35 is too short for 215, why do they have em? Or is just an all wheel thing?
  9. predavore
    predavore Well-Known Member
  10. predavore
    These Subarus seem to have a speedo that reads a bit fast. So I actually run 235/40/18 and I'm about dead on.
  11. readymix
    Stock reference size for tires for an Impreza is a 17x7.5 wheel with 225/45/17 tire. Your car never came with a 215/35/18. Maybe you purchased it with those on it, but that doesn't mean they are the correct size. And just because a 215/35/18 doesn't work on an Impreza doesn't mean it doesn't work on other cars.
    The speedometer on the Impreza is calibrated to a 225/45/17 tire's circumference on a 17x7.5 wheel. When you use the Miata.net calculator, the first thing you plug in is the reference size. The closest you can get to that circumference in an 18x7.5 wheel is a 225/40/18.
