WTB 99 RS rear knuckle/Hub
Discussion in 'Want To Buy : Cars/Parts' started by Squiggly, Sep 15, 2009.
  1. Squiggly
    Squiggly Squiggly
    Over the weekend the drivers side rear knuckle/hub started to come loose on our 99 RS. With the axel nut and the lugs tightened all the way down the entire hub still has a lot of play.
    Let us know what you have, new or used.
    Thanks,
    Mike
  2. putz
    putz Well-Known Member
    that would be a disc hub knuckle? right?
  3. Squiggly
    Squiggly Squiggly
    Correct
  4. prezawagon
    prezawagon Well-Known Member
    The knuckle and hub are the same between drum and disc brakes, you just need to swap the backing plate, although doing that you should probably change the bearing and seals at the same time.
  5. Squiggly
    Squiggly Squiggly
    If possible we would like a complete unit with the bearing already installed so it's a quick change over.
    Mike
  6. Squiggly
    Squiggly Squiggly
    still looking~
  7. Squiggly
    Squiggly Squiggly
    We really need one!! I know someone has one laying around from a wrecked car or swap.
    Mike
  8. phi11
    bump!
  9. Chux
    why do you need a whole new knuckle? just replace the bearing.
  10. Squiggly
    Squiggly Squiggly
    Utech said he believe the threads have actually stretched and that's why there's such an excess in play. It's more then the standard wheel bearing wobble, the car couldnt even drive in a straight line.
    Mike
  11. putz
    maybe you have an unusualy bad bearing?
  12. Squiggly
    Squiggly Squiggly
    It's possible, I figure it would be cheaper/less of a hassle to get a used/pre-assembled hub though. If all else fails we'll probably look into just the bearing but for now i think we wanna stick with the whole unit.
    Mike
  13. Squiggly
    Squiggly Squiggly
    Still lookin
  14. Squiggly
    Squiggly Squiggly
    Big Bump
  15. Dynapar
    I have a pair of 2006 WRX rear hubs and knuckles w/ brake rotors (for 2pot rears). Not sure if those would help or not. I want to sell them complete and as a pair though.
  16. Squiggly
    Squiggly Squiggly
    Appreciate the offer but we only need the one hub at this time.
    Mike
  17. Dynapar
    Gotcha, just thought I would put it out there.
