I need the little brass compression fitting that goes on the nylon hose for a boost gauge. Does anyone have one or do you know where you might find one/ Thanks Rich
I will see if I can figure out how to do that, I didnt like the crappy nylon line they gave me with it. It leaked right away, thats why I needed the fitting
Anything is better than DOT nylon airlines. Period. I don't even know why they still use that crap on big-rigs. I've converted a couple dozen minitruckers away from using DOT nylon air lines in their suspension setups. Try finding a rubber vacuum line the same size and use a barbed fitting found at any hardware store in the brass fittings section, then just use a small hose clamp to make sure the barbs don't slip as well. Don't forget to use some pipe sealant on the fitting so it doesn't leak as well.
IIRC, its just a 1/8 NPT on the back of the gauge, right? One should be able to find a female to a hose barb.
yes its a 1/8th male npt on back, I have a 1/8 npt male to barb but I cant find a female to barb end. Does anyone have a male to male union or a female to barb fitting? cant find anything around here and would like to know what kind of boost my sled is running this weekend.
