WTB: Coolant Hard Line
Discussion in 'Want To Buy : Cars/Parts' started by Blageo23, Dec 7, 2009.
  1. Blageo23
    Blageo23 Well-Known Member
    I need the coolant line that goes from the water pump to the back of the engine(to the heater hose i believe). Mine has a hole in it. For a 98 legacy with a phase 1 ej25. Let me know what you have!
  2. Bielke55
    You need the metal line?
  3. errorcode3
    errorcode3 Member
    i have one give me a sec to find it, and i'll take a pic just to verify
  4. Blageo23
    yes i need the metal one. there was a hole in it. when I sand blasted it it showed up. idk if it was there before or not. probably cause my overheating issue
  5. errorcode3
    errorcode3 Member
    like this?
  6. Blageo23
    Yes sir that is it. How much do you want for it? whats the condition of the small part hard line? thats where my hole was.
  7. errorcode3
    errorcode3 Member
    now i see what you are talking about, i bet yours had rust on the top, just like mine does.
    after seeing that it probably puts you in the same place, i can peel the rust off and check if there is indeed a hole.
    i just hit it with my dremel, i don't see any holes in it.
  8. Blageo23
    if you could do that that would be great. thanks for your help!
  9. errorcode3
    errorcode3 Member
    you have pm
