WTB: DCCD Controler
Discussion in 'Want To Buy : Cars/Parts' started by JasonoJordan, May 24, 2010.
  1. JasonoJordan
    looking to buy a DCCD Controller im doing a 04sti 6speed swap into my 02. anyone have one
  2. Dynapar
    Orono, MN
    You are probably going to want to go with an aftermarket one. if you were to swap in the stock STi one and want the Auto mode to work you are in for a heck of a lot of work. (ie swapping ABS systems, and what not).
    I went with the DCCDPro controller and have been very happy. For the price it is a very very solid option. Otherwise I have heard some excellent thing about the GEMs controller, but that is getting kind of spendy.
    http://dccdpro.com/
  3. JasonoJordan
    Yeah I've heard a lot of peaople use one called spider or something like that as well
    Sent from my Droid using Tapatalk
  4. stoooo
    stoooo Well-Known Member
    North Yorkshire, UK
    DCCDPro is the one made by spiider. Clever stuff it is, too. Self contained using accelerometers and complicated mathematical algorithms instead of a cell map type of system.
  5. JasonoJordan
    ok cool, how hard is it to add in after the fact?
  6. idget
    falcon heights
    There's TONS of info including install manuals and wiring info in the link Martin gave you.
    Don't be scurred. Click the link. It's not for penis pills or a Nigerian scam.
  7. JasonoJordan
    hahaah thanks i was on my phone so viewing some of the webpages dosent always work the best.
  8. Dynapar
    Orono, MN
    It was pretty easy to install.
    1 wire get T-ed into the TPS signal
    1 wire is switch power
    1 wire is a ground
    2 wires go to the transmission harness
    1 wire goes to the E-brake
    Glue the G-sensor to the car.
    Done.
  9. JasonoJordan
    sounds like something that i could install after the fact then coorect?
  10. shineynitelite
    st. paul
    i got the manaual dccd controller from dccdpro.com and i like it a lot, i didnt have a bunch of money to spend so for 200 shipped i'm more than happy with it.
  11. JasonoJordan
    with the manual one its just a dial that the more u turn it the closer 2 4x4 u get rather then the stock setting?
  12. Dynapar
    Orono, MN
    Yes, I ran my 6 speed for several months w/o any sort of controller. Than a month or so ago I put in the DCCDPro controller. Works just fine
    The manual one is just the adjustment knob. It allows you direct control over the DCCD but there is not automatic mode so if you want the DCCD settings to change you need to do it manually. With the automatic controller you can set the intensity of the automatic mode and than the controller itself will determine the DCCD setting based on supplied inputs (TPS, G-forces), you can also switch to manual control as well.
  13. JasonoJordan
    ok cool thanks for all the info.
