WTB: Dirt 16" rally-x tires/wheels OR set (4) of 16 inch rims, (100x5 lug)
Discussion in 'Want To Buy : Cars/Parts' started by hex2bit, Mar 12, 2010.
  1. hex2bit
    hex2bit Well-Known Member
    I'm looking to put together a dedicated set of wheels for dirt/gravel rally-x. My car's a 2004 FXT, and I want to stick with 16 inch rims (100x5 lug pattern). If you've got some stock rims lying around, condition doesn't matter, as long as the rims aren't bent. I'd grab a set of steelies from Tirerack, but they are out of stock for at least a month and half. If you got a set of dirt/mud/gravel rally-x tires/rims already together in decent condition, let me know as well. I'd like to stay close to stock sizing (around 26 inch diameter). Thanks!
  2. Vector
    Vector Rally Organizer
    For tires for Rally-x, get a set of Firestone Winterforce tires ($67 ea from Tire Rack). Steelies aren't the best idea for rally-x, as they bend easily and in extreme cases can metal fatigue around the lugs as well.
    For wheels you can either pay about $85 each for some alloys from tirerack, or try to find someone selling some stock WRX 16" wheels, which come up for sale pretty often, and will proabbly be a little cheaper and stronger.
  3. hex2bit
    Actually, I'm looking to try out the Cooper Weather Master S/T 2 tires, which is about the same price as the winterforce, and I like the squared off block pattern and the few that have run them like them.
    I'm hoping to find a set of stock 16" rims, but I'll grab a cheap alloy set if I don't find something in the next couple weeks.
  4. dmoo
    dmoo Well-Known Member
  5. hex2bit
    Unfortunately I'm running Tokico Dspecs, and won't be able to run truck tires due to clearance issues. So I can't run 27 inch diameter tires any more, until I go to coilovers sometime in the future.
