wtb: downstream o2 sensor
Discussion in 'Want To Buy : Cars/Parts' started by xodad2, Nov 19, 2014.
  1. xodad2
    xodad2 Well-Known Member
    Coon Rapids, Minnesota
    I have an 02 wrx and I'm looking for a downstream o2 sensor(the sensor that goes in the downpipe).
    would like it to be oem style plug-in.
    Lmk thanks,
    Josh
  2. EricS
    EricS Nooberator
    Saint Paul
    I have one Josh, from my 05 with about 65k miles on it, was working fine when I pulled it recently. Is $60 a fair price? Send me a PM if you want to work out where/when to meet - how soon do you need it?
  3. bob
    bob Member
    I also have one
  4. xodad2
    Anyone know if an o2 senso from an 05 will work on an 02?
  5. bob
    bob Member
    I think it's 02-04
  6. thomas franz
    Anoka, Minnesota
    It should be okay. I would imagine 06-07 would work too? I'm assuming your getting a code? Not sure if this helps or not but a bad FPR can throw downstream codes too.
  7. xodad2
    THanks for the info.
    No codes, going with a new turbo back exhuast and would rather have another o2 sitting around just in case the old one is too stuck or gets damaged when I pull it. I've had that happen a few times.;)
  8. xodad2
    I know I've seen this in my googling but not sure if I just didn't Google it enough.
  9. bob
    bob Member
    Did yA find one then?
  10. Ryan FailRad
    Good thinking! Also be carful when you are doing that, I cut half of my knuckle off when I was doing mine. If you're not already aware, there's actually a specific socket that you can get to remove the O2 sensor.
  11. Terry Ammerman
    Elk River, MN
    New o2 is 30 bucks. As for the wrench, just unplug and feed the wire through a 7/8 box end wrench.
    EricS likes this.
  12. xodad2
    Where can you get a new one for $30?
    I do have a o2 wrench and I've heard of feeding the wire through a 7/8 box wrench.
    thanks guys
  13. Terry Ammerman
    Elk River, MN
  14. Ntxhuav_Khang
    Saint Paul
    Aren't the up and down stream sensors different?
