WTB: Ej22t Pistons
Discussion in 'For Sale : Car Parts' started by Ej22TIM, Feb 12, 2008.
  1. Ej22TIM
    Ej22TIM Well-Known Member
    oem, wiseco whatever.
    I have searched for pistons to no avail :(
    I dont want to do all this work for just a re-ring kit, I want new pistons and all this.
    anyways who knows of a good reputible place to purchase 22t pistons?
    thanks
  2. FuJi K
    CP makes pistons. I am going that route for my pistons later.
  3. readymix
    You can get the wisecos from Summit for 440.00 a set shipped. But they only come in overbore sizes I believe. 97.5mm and 98mm. And when you get them, have someone with piston experience make damn certain the wrist pin retaining clips are correct. They sent me the wrong ones and, well, you know what happened with that.
  4. Shibbs
    I'm still sad about that. :emo:
  5. Ej22TIM
    thats actually not too bad, I was planning on doing delta cams but I was dissuaded, for what I want to do, the 20g heads will flow and perform far better than what I expected.
    as far as making sure the retaining clips are correct, could I go to any machine shop?
    also jason, where did you get your cyls punched out and what was the rate?
  6. Ej22TIM
    also, my rods will be good for about 230-240whp right?
    maybe some new rods too eh?.......
  7. curly2k3
    IMHO, if you are in there you might as well do rods and balance it all out.
  8. Ej22TIM
    this is true, but from what I have read the 22t rods are very strong stock and are good past 300hp. theres a guy on legacycentral that put 20k on his block with stock rods at 400whp, so maybe I will look into getting rods, or just have mine tested for cracks....
    what do you think?
  9. curly2k3
    They are very strong, yes, however, why not spend the money now and not deal with it down the road, especially when you get the itch for something more? As I stated, I would personally go pistons and rods and balance out the whole moving assembly while you are at it. Do it how it should be done the first time and dont worry about it again.
  10. Ej22TIM
    yea, that makes sense, "overbuilding" for now and heck in 3 years when 02 wrxs go for 5k I will swap the 22t in there!!!
    this idea ftw
  11. curly2k3
    i know these things tim...i know these things. build it, faster...stronger...better than it was before.
  12. Ej22TIM
    like a woman, made of legos
  13. Ej22TIM
    now I need to know what a good place to get my block bored is?
  14. curly2k3
    D&G and Headwerks, those are basically the two shops i would trust with my stuff.
  15. FuJi K
    hey I'm still using EJ22T rods.... but I tell you, my next build I will be using STi rods.
    At least put in some STi rods. That's what I'm doing next.
  16. Ej22TIM
    that dosent change the stroke at all?
    sounds like a good idea
  17. curly2k3
    Atleast, i still say if you are in there, do it right the first time.
  18. FuJi K
    Here's a secret, 1.8L, 2.0L, 2.2L, 2.5L(EJ257) rods are the same length. 2.5L NA are a tad bit longer.
    DO IT!!!
  19. piddster
    STi rods really aren't worth it if you're going to get all teh seals and everything necessary to swap out connecting rods. Eagle's are cheap, and significantly beefier than STi rods. Don't waste your time.
  20. curly2k3
    again backing what has been said. dont be dumb tim. do it right the first time.
  21. Ej22TIM
    thats what I wanted to hear, I will look into eagles, thanks dan.
  22. piddster
    Connecting rods holding has a lot to with tuning. NICO catastrophically blew his 22T with not that large of a turbo, yet innovative rocked a bone stock 22T longblock for quite some time with a 35R, untill the spun a bearing from over-revving the motor. You do the math
  23. piddster
    BTW, Dana's in Shakopee did a great job on my block. Only a trace amount of slap when it super cold, it was amazingly clean and void of all silicone, and a super nice guy to work with. $130 for the .020 overbore, tank, and check.
  24. Grayguy
    Grayguy Well-Known Member
    I've decided recently that since i have to go through all the trouble of pulling my motor out and apart, I'll be going with the wiesco/eagle setup. Like everyone else is saying, it just doesn't make sense to not do it while your in there now.
  25. AWDimprezaL
    DG motors ftw indeed, tim i have the number for them if you do decide to go that way
  26. FuJi K
    so I lose then??? booOO
    okies.... 300-350whp w/ STi rods no good? 8k revs!!! eh???
  27. piddster
    You don't loose Fuji. I just feel it is a lot of work and money in seals and bearings to replace your rods with something marginally better than what is already there.
    Rev to 8k? Its possible. IIRC, your heads still have HLA's, so thats questionable. Even still, I hope you plan on serious balancing(static and dynamic) and checking of ALL tolerances, not just oil clearances. Cleanliness would also be of the utmost importance. Revving that high is really tough on the rod bearings in a boxer engine and any contamination that gets in there from assembly will seriously shorten their life.
  28. Ej22TIM
    I would like that number, I have decided to go this way.
    like I said before, I would rather have a stout engine that I wont test to the extreme by any means, rather than an engine that has re used pistons and new rings........... that would be fail......... it will take longer to save for but, the geo is getting a fresh rebuild on a spare block, so I will be saving all sorts of money that way.
    I found eagles on ebay for about 350 shipped, does this sound about right?
  29. piddster
    Yup, sounds about right.
  30. AWDimprezaL
    612 237 3145, "guy" tell him your brother works at morries subaru
