if i can find mine you can have it for 20 bucks... 04 wrx though, you would need to check fitment _Dan
it quite effectively keeps cones from getting jammed up against the headers.... doesn't hurt to reduce drag on the underside of the car.
Doesn't do anything?? Might want to install a real water temp gauge and re-think that statement. The undertray helps pull the underhood heat out to the tune of 10-15 degrees. Russ
found it, feet and garbage can not included for purchase price. yes its dirty i can clean it if you are interested. remember this is from an 04 so you can for sure test fit it 20 bucks still... -Dan
