I need forester suspension. Preferably fxt, but any forester will do. Struts and springs. From the outback, I need the following: -rear sway bar -rear sway bar mounts -trailing arm mounts -trailing arm brackets -cross member spacers -front & rear subframe spacers -differential subframe spacers and brackets -transmission crossmember and bolts -steering knuckle -exhaust shield bracket -center driveshaft bushing -muffler -cash in hand 952.484.8945
Oh my...what are you up to? How soon do you need these things? I will have Fxt stuff available soon...
I'm not sure how much taller the 03-07 foresters are a little taller, so I'll stick with those years. I'd rather have FXT for a little extra stiffness, so I'll be first in line for Moleness's setup.
If an 03 WRX crossmember would work, i have one mang. Not sure if i have the hardware for it tho, but Morries does.
Josh, I'm looking for the spacers from the crossmember, but apparently its all one piece. I believe your wrx has the same ground clearance as my brighton (6.1")
Still trying to find it brotha. I may have to do some major cleaning and reorganizing of mah gayrog. It's got to be in a box somewhur!
