WTB: Front Brake Caliper Parts 04 WRX
Discussion in 'Want To Buy : Cars/Parts' started by pbedroske, Jun 6, 2010.
  1. pbedroske
    pbedroske Well-Known Member
    I managed to shear off a 14mm bolt on the slider that attaches the caliper to the caliper bracket. I need mainly just the slider or the slider and the bolt.
    Let me know what you've got or where I can find such a thing.
  2. predavore
    predavore Well-Known Member
    Been there, done that. Did it break off flush or is some sticking out? I lucked out and had a little stub. I flattened the sides, heated it up, and wrenched it out.... slowly.
  3. pbedroske
    it broke off flush. tried drilling it out, no luck, just 2 broken drill bits. tried hammering a torx bit in the drilled hole, the bit shattered that into pieces when i tried turning it out. I suppose I could get a bolt extractor from menards. at this point I'm ready to give up and just get a new slider.
  4. pbedroske
    Anybody!?
    Do autoparts stores carry these? or should I order one from a dealer or rockauto.com?
  5. errorcode3
    errorcode3 Member
    how different are these from an older 2.5 rs? since i have a set from those, just unsure if they are even close to the same.
  6. Bielke55
    These should be the same PIN and Bolt from 02 - 05 Imprezas and 06-07 2.5I Impreza.
  7. pbedroske
    it's probably the same as a 2.5RS.
    I'm going to search around town after work to see if I can find one at an autoparts store.
  8. pbedroske
    Well I guess Autozone carries these. So I got them and they fit perfect. Crisis averted.
    Mods can delete.
