All parts are for an 02 sedan passenger tail light Glove box Wingless trunk color doesn't matter Washer fluid res with pump I'll add more later but that's the start of it.
Passenger a pillar plastic trim, plastic around the shifter, oem headlights, good/ rebuild ej205 heads, washer fluid res with pump, upper coolant res
Picked up short block, tail lights, caliper, side skirts, pilar trim, and rear pads and rotors last night. Still need heads, both washer and upper coolant res, trim around shifter, potentially a triple clock pod, or double gauge bezel, shaved trunk lid, oem timing belt, gasket kit just to list a few more
Washer res cap, upper coolant res, dash clock or triple pod with gauges/ dual gauge bezel with gauges , plastic trim around shifter, sedan trunk cardboard, decent headlights, front bumper lip (a subtle kind), possibly passenger side doors, ac pump tensioner pulley. And if I can't find a wingless trunk I'll just weld my holes
