WTB: hubcentric rings
Discussion in 'For Sale : Car Parts' started by gran0393, May 16, 2008.
  1. gran0393
    gran0393 Well-Known Member
    ok so i was stupid and bought new wheels without buying rings and now i figured out i needed them i want to buy a set...if anyone has a set i'd like to grab it otherwise what size do i need? i have 17" rota torques on a 02' WRX
  2. Se7enrex
    Se7enrex Well-Known Member
    don't buy them, waste of money....Our contact at Discount will tell you up and down that they are a waste of money...just saying
  3. idget
    They're not entirely necessary on lug centric wheels, but if you want them you can get them here:
    http://www.wheeldude.com/catalog/product_info.php?products_id=295
    or pretty much any tire place.
    According to Zoeb at Wheeldude.com, Subaru fitment Rotas are only made in 56.1mm hub bore and a 73mm hub bore. So it sounds like you would need a set of 73 to 56.1 rings.
  4. gran0393
    well i didn't think i needed them but i'm getting a wobble at speed and my wheels are perfectly balanced so i'm assuming they will help
  5. Sogonerg
    Sogonerg Anteater
    beg to differ...you need another contact
    Don't get the metal ones, POLYCARBONATE is best, it should only be around $10-$15 for a set of 4. I took them out of my current rims and forgot to put them back in and @ around 70 mph your steering wheel will start to shake. I wouldn't play around with this especially only @ $15; spend the cash and be safe.
  6. idget
    Why do you say that?
    The only downside to aluminum rings I've seen in my personal experience is more corrosion as water gets trapped between the hub and the ring. Easily fixed and preventable with a very thin coat of high heat spray paint.
    Every set of polycarbonate rings I've had have either broken or melted to the hub (of course I'm heating them up more than usual with autocross use). They have worked fine on my daily drivers however.
  7. Sogonerg
    Sogonerg Anteater
    NORMAL DRIVING CONDITION, now get back to work...I got the aluminum ones and it corrode and can bend in time. Ploycarb is just my preference...but again, I don't drive that often anyways...
  8. Se7enrex
    i have never had rings or wobble at 130mph+ I guess I dont understand how you guys do:ugh::ugh:
  9. Iroc-Z
    Iroc-Z Well-Known Member
    Just buy the rings. I have had problems with wobbles on cars that do not have them.
  10. gran0393
    so what size do i need it it the 56.1-73mm?
