Full harness with ECU Driver intake cam Gear Timing crank sprocket 20mm or Larger Rear sway bar with bushings Turbo cross member *(Any turbo model will be fine)* Power steering pump Power steering pump reservoir Power steering lines
I have left side cam gears. and pretty sure I have a timing crank sprocket. PM me if you still need them
Check out my forsale thread. I have a power steering pump forsale. http://mnsubaru.com/threads/fs-ej20-short-block-02-center-console-02-wrx-heads-other-stuff.48469/
*UPDATE* -Front sway bar mounting brackets with bolts -Front rack & pinion mounting brackets with bolts -02-05 WRX Diff 3.54 -02-05 WRX ECU with Full Harness (headlight to Taillight) -Lowering springs for 02-05 WRX wagon
