wtb motor mounts
Discussion in 'For Sale : Car Parts' started by silver03, Mar 13, 2009.
  1. silver03
    00 Impreza 2.2L...anyone? and will WRX mounts fit? thanks
  2. Snowbum
    Snowbum Well-Known Member
    I'm about 90% sure I have mounts for you.
    wrx will fit.
  3. qstarin
    qstarin Well-Known Member
    I also have stock 2.5 RS mounts in a box ready to go. Not 100% positive if they work/fit, but I'm guessing they would. Will also have stock wrx mounts sometime later this year (not yet).
  4. Snowbum
    ^They should work. IIRC any EJ-engine mounts are interchangable, but I could be wrong lol.
  5. silver03
    ^^looking for low(er) mileage OEM ones. Mine have about 105k on them and are tired, very tired. What do you have and what would you want for them?
  6. idget
    If they work, I have some oem 07 sti ones. 8-9k miles on them.
  7. Snowbum
    I have a set from a 22t block, unknown milage, but probably higher then what you're looking for.
  8. qstarin
    Mine are 01 RS w/ about 85k miles on them. In quite good shape. Can post/PM pics later. I'm thinking maybe $20 is a decent deal? Comes with the rubber and the plates, in case that isn't assumed.
  9. EtchyLives
    EtchyLives Well-Known Member
    EJ-series motor mounts are the same regardless of platform.
  10. silver03
    Q, thanks, but i am looking for some with low(er) miles. R
  11. readymix
    Etchy is correct, the threaded holes on the EJ series blocks are the same for the engine mounts across the board. Any EJ engine mount will work on your block. If I were you, I'd go to the dealership and just get a set, they aren't that expensive really.
