WTB: OEM Battery Tray
Discussion in 'For Sale : Car Parts' started by Moleness, May 26, 2009.
  1. Moleness
    For my '04 STi. I need the plastic tray that the battery sits in. Mine is torn where the metal hook thing goes in.
    Not sure what other model years work. I am guessing any Impreza from '02-'07?
  2. ikpthegame
    ikpthegame Well-Known Member
    you should be able to just not used the tray. the hooks latch onto the metal base under the tray. im not using mine right now and not a single prob.
  3. carl
    we took it out of the rally car. you can have it if I find it
  4. Moleness
    I thought it actually went into the tray. I will take the battery out tonight and have a look. Either way, I can't get the thing to not pop out.
    Thanks Carl :)...I will pm you later after I look to confirm that the battery tray is indeed the problem
  5. n1ck
    n1ck Well-Known Member
    It's kind of a bastard to get it to hook in - do the rear one first. It hooks to the metal base under the tray.
  6. Moleness
    So, I could have sworn by feeling down there that the tray was torn but, upon further inspection, the hook had pulled through the metal :ugh:
    Dangit
    I beleive I will remove the grill/headlight and drill a hole next to it lol.
  7. ikpthegame
    now what did you do to pull that off lol.
  8. n1ck
    Haha, that is some serious battery tiedown tightening.
  9. Moleness
    Not sure how it happened. As long as I can remember, I could only tighten the front a bit or it would pop out. Wasn't a problem until lately, must be the mad g's from autocross, yo! ;)
  10. ikpthegame
    True, and all the jumping also.
