WTB: Pistons & Rods for a EJ257
Discussion in 'For Sale : Car Parts' started by Bielke55, Jun 11, 2008.
  1. Bielke55
    Whats gonna be the best for the EJ257 block to run?
    I'm looking to get upwards towards 20+ PSI of boost.
    Is any one company cheaper, better, or both?
  2. readymix
    Mahle pistons are nice, and are coated.
    For 20PSI of boost, you could pick just about any aftermarket rod.
  3. readymix
    And you can find Eagle rods on the cheap on eBay if you look.
  4. Dream
    I ran stock rods and Mahle pistons pushing 450+ whp (28+ psi). Never had issues with either.
  5. shineynitelite
    :cool:
  6. KSAL
    KSAL Well-Known Member
    I have a set of coated Mahle pistons for sale. PM me
  7. Paul Revere
    Where did you get this block?
  8. Bielke55
    How much? Forged?
  9. Bielke55
    Dont worry about it
  10. Paul Revere
    Was this 3riks used block that was sitting at Morries?
  11. Bielke55
    NOPE...
  12. AWDimprezaL
    wtf are you talking about?
    the only block i HAD was a 2.0 GTFO of this thread troll.
  13. KSAL
    $220 and yes
  14. Bielke55
    New? 99.2(or.5)mm?
  15. Scuba Steve
    gotz block? Very nice. have fun with the build. that car will scream with all that power
  16. KSAL
    They are used and yes they are for the stock 99.5mm
  17. Bielke55
    Well i do appreciate the offer but I'm gonna go new.
  18. KSAL
    That works but they are gonna run you like $465 new. Lemme know if you change ur mind!
  19. Bielke55
    New Crank =$296.34
    New Crank Bearings =$145.80
    New Rods =$230.40
    New Rod Bearings =122.56
    New Pistons =$520.26
    Total = $1315.36
    VS.
    New STI Short Block = $1595.03
  20. Dream
  21. Bielke55
    That was the most that i found...
  22. Ej22TIM
    Ej22TIM Well-Known Member
    looking at your prices it looks like you are going to use oem bearings? get some aftermarket ones for cheaper and more safety.
  23. Bielke55
    Where?
  24. Ej22TIM
  25. Bielke55
    Standard or Race Bearings?
  26. Ej22TIM
    the "race" is just a series of higher quality bearings that ACL offers, you specify your engine and bearing size (im assuming std.) when you buy it. I would click around in his ebay store and look for a 1-800 number and talk to a real person.
    I would definately go this route though.
  27. Sogonerg
    Sogonerg Anteater
    Is that your cost??? geez...I thought it would be aronud $1300, a stock STI block should be able to handle 20psi if tuned properly...
  28. Bielke55
    he he he this is just a list
  29. piddster
    No no no. Call Calico for bearings. That is where Cobb and others get their bearings from. Derek paid $160 total for rod and main bearings.
    http://www.calicocoatings.com/
  30. Dream
    A completely stock block should be able to handle 20psi (with a good tune of course), no need to get race or forged anything IMO, and last for a long time.
  31. piddster
    Very true.
    20psi is also relative. 20psi from a 20g and 20psi from a 40R are two completely different things. Specify a specific HP goal and then people can actually help.
  32. tux121
    tux121 Well-Known Member
    I thought Eagle didn't make drop in rods for Ej257 blocks?
  33. Bielke55
    The block has bad bearings and crank. So I'm replacing now internals before i swap the two.
  34. Dream
    20psi on a 40R would be a waste. Agree'd though, posting your goals would help! :)
  35. Bielke55
    I wanna get close to maxing out my T28. They say it can handle 28 PSI IIRC.
    Soooo my build is going to be the following:
    EJ257 New Internals
    P&P Intake and Heads (gasket matched)
    Larger Injectors
    300+ WHP
  36. Dream
    Sounds like a fun setup. I would suggest forged pistons, stock everything else. You might even be better off buying a new short block from Subaru and dropping in the pistons. Good luck!
  37. piddster
    What compressor wheel is it? Do you have a compressor map for it? Who is they?
  38. Bielke55
    At "my pricing" working with a used block adding brand new internals. I walk away saving like $500.
  39. Bielke55
    They @ Garrett
  40. piddster
    Depends on the motor. Stock 2.5 yes. Ported to hell, no its not. 20psi is running right across the most effcient region on it's compressor map. You just have to flow enough and rev high enough to take advantage of it.
    When you look at a 35R's compressor map, you also see that they are more happy on larger displacement motors with low boost. Not that they don't make nice power on smaller motors. The next turbo I get may be a GT3782, and hopefully someone can put together a watercooled ball bearing variant. A 3782 will spool faster and be much more efficient at higher pressure ratios than a lot of other turbos in that airflow range.
  41. Bielke55
    Heres my turbos compressor map
  42. piddster
    From the looks of that map, a pressure ratio of 2.5 is starting to push the limits of it's effeciency. So at sea level, a 2.5 pressure ratio is 36.75 psi minus atmospheric of 14.7 means you are at about 22psi. You also need to account for any losses like intercoolers and what not.
    Here is the map of my turbo. Mine will be happy up to 26-28psi before accounting for any losses.
  43. Snowbum
    Snowbum Well-Known Member
  44. Bielke55
  45. Bielke55
    Also!
    WTB Rod Bearings and Crank Bearings!
    Stock?
    Cosworth?
    ACL?
    Other?
