WTB: Potassium Nitrate (AKA Saltpeter)
Discussion in 'Off-Topic' started by Moleness, Jan 25, 2013.
  1. Moleness
    Wondering if anyone knows where to find it locally...or if you could steal some from your child's chemistry set for me. I only need 2 tablespoons.
  2. SurlyOldManMN
    Ah, just a small explosion then? ;)
  3. Nuke
    Are you making your own sodium nitrate?
  4. phi11
    mmmmmm.... cornbeef
  5. thakrazymule
    thakrazymule Active Member
    Mmmm..... saltpeter.... Wait! What?
  6. Moleness
    If you mean corned beef, then yes!
    phi11 likes this.
  7. pillboy
    This used to be readily available at a pharmacy back when I worked for an independent. I just checked our (the one my current employer uses) wholesaler's on-line catalog and they list two sizes (4 oz and 16 oz) but neither are stocked at their local distribution center. Cost to the pharmacy for the 4 oz size is $4.09. You could try a pharmacy and see if they stock it (most likely it won't me out front on the shelf) or could order it for you.
  8. Subie Lovers
    Will a banana and a 08+ STi crank work???
  9. Moleness
    My friend has a crank I can borrow, but I am allergic to bananas, so I ended up going with another recipe that used a more readily available pink salt ;)
