WTB Read & Clear SRS Codes
Discussion in 'Want To Buy : Cars/Parts' started by jdub13101, Oct 26, 2009.
  1. jdub13101
    jdub13101 New Member
    Looking for Subaru tech to read codes in airbag light, then clear light from dash (if possible). 2002 WRX, was in accident, airbags, control module, clockspring replaced. Can't find connector myself under dash. Would appreciate help, have cash money.
    Thanks for looking.
    Regards,
    John Wolf
    (612) 275-5296
  2. subytek
    subytek Well-Known Member
    As long as there is a problem, you can not clear the code(s).
  3. issues
    issues Well-Known Member
    Airbag codes are hard codes if the problem is fixed it will go away. If you want to check if it's a soft code remove your batt cables ( touch them together for a sec this will reset your comp it will not hurt it, it will set it to default settngs) or just turn your lights on and wait 20 min will do the same thing. If it's soft it will go away if not the scaner will your next best option
  4. jdub13101
    Still looking for help pulling the airbag codes without going to the dealer.
    Thanks,
    John Wolf
  5. subytek
    If you want to meet up in the west metro sometime, PM me. I busy this weekend though.
