does anyone have an exhaust shield that goes on the rear bumper cuz its starting to burn. or longer exhaust hangers. any help would be sweet
must have a aftermarket bov.....put a stock one on! is it burning or just turning brown? if its just turning brown, go to a autoparts store, and buy a product by eagle one called NEVR DULL, its wheel polish but takes the burnt look off very well without ruining the paint.
no it still has the factory recirc on, and it just melted the bumper a little bit so either longer exhaust hangers or a shield would do. as for the burnt look ill look into the never dull
Would advise NOT using never dull since it is a wadding polish used to buff fine scratches and tarnish off of metal surfaces and will likely eat your clear coat off. Go get a bottle of 3M fine cut polish and use a towel to apply it by hand. Keep the surface somewhat wet while using it. Then let the surface dry and buff off the residues with a CLEAN towel.
^^^^ this....thanks for actually trying to help lol...does anyone else have the issue of the can too close to the bumper?
**** off, I did try to help. That'll be the last time I give you good advice. Go buff your paint with metal wadding polish, it's a good idea.
ok devil fix this for me.....after the leak ( THE GAP) was fixed the can moved over and up i want either a gaurd or longer hangers would do to.
