WTB: Rear wrx/legacy brakes
Discussion in 'For Sale : Car Parts' started by Justin, Jul 12, 2007.
  1. Justin
    Justin Well-Known Member
    i need to get the crappy L rear brakes off asap. need the calipers, rotors, and if you have the pads, great.
    thanks
    Justin
  2. Threshld1
    Threshld1 Well-Known Member
    I have some some working condition t-lego rear calipers if it helps
  3. Justin
    are the old school t-leggy rear brakes an upgrade over the wrx's?
  4. Threshld1
    I believe they are the same except the revised float pin setup. The t-leggy rotors are vented and wrx 02-05 are not. Someone do correct me if im wrong
    Nasioc lists them as an upgrade (due to vented) here:
    http://forums.nasioc.com/forums/showthread.php?s=&threadid=243337
    It might limit your pad choices though. Not looking for much at all for them, let me know
  5. wrxjoe
    wrxjoe Well-Known Member
    I've got new stoptech pads for the rear of a wrx, they didn't fit my 03 so I don't know what year they are for
  6. Deride
    Most WRX and RS brakes are the same.... you are way better off going with the solid rotor WRX/RS setup than the legacy turbo vented one for parts reasons. I just spent quite a bit of time finding/buying brakes for my turbo legacy because they are vented. I really don't think they have much more performance than my solid 02 2.5rs rear brakes. If you do upgrade go with the 2 pot 06+ rear calipers/rotors they will be cheaper to find parts for in the future.
  7. Rexwagon
    Rexwagon Well-Known Member
    i have the wrx rear rotors and pads and lines.
