Just in case anyone has this stuff lying around, I'm looking for: 22750AA010 - STi/WRX FPCM 15010AA360 - 11mm oil pump 10105AA720 - Engine gasket kit 14459AA340 - Turbo inlet 807515712 - Turbo oil drain hose 11051AA070 - Cam half-moon seals (4) 806718180 - Shift shaft seal 32145AA030 - Transfer case gasket 21200AA072 - Thermostat 21236AA010 - Thermostat gasket GrimmSpeed UP and DP gaskets ARP 260-4701 - ARP head studs Gates TCK328 - Timing belt kit Gates 43548 - Water pump Thanks for looking!
22750AA010 - STi/WRX FPCM bought from r6rippin, thanks! Still looking for the rest, will order new in a few days if noone has anything...
Sounds like engine build time I have the remains of the engine rebuild gasket kit from what wasn't used on my engine build, so I may not have used some of the main ones that you need, but you're welcome to see what I have left. On a side note, I did buy an assembled shortblock, so I should have a lot of the "internal" gasket stuff...but I have not idea how much that helps your case.
Thanks, but yeah, I'm going to need pretty much everything... Thought about that, but I've read lots of fittment complaints & I'd rather keep an OEM look. There're all over $200 when an OEM replacement is only $85 and I don't think I'm really moving THAT much air where it's going to make a big difference... Maybe I'll do a little more reading on the subject.
