WTB:STi Hood Scoop Bellow
Discussion in 'Want To Buy : Cars/Parts' started by tangledupinblu, May 3, 2012.
  1. tangledupinblu
    As the title says! I already have the JDM STi hoodscoop and the STi intercooler, just need the bellow that mounts under the hoodz. Lmk if you have one and what you would like for it.
    TIA!
    -Josh
  2. Deride
    The JDM part number is 90817FE120 if you can't find a used one.
  3. tangledupinblu
    Thanks! I was hoping that someone here has gone FMIC and may have one laying around. If not, i will be looking to just grab a new one. I'm sure they're cheap...just like all other OEM parts. lol
  4. tangledupinblu
    Also known as "splitter"...in case anyone read the title and was like "Wtf is that?"
  5. fobiawrx
    fobiawrx Fabiola
    we should have two laying around. pm me if you dont have my number. i will check later to see if i can find them
  6. Deride
    Has to be from a jdm bugeye, I tried 04-05 it doesn't fit the jdm bugeye sti scoop.
  7. tangledupinblu
    Not even with modifications?:confused:
  8. Deride
    With "modifications" you could make anything fit. The problem is the scoop on the 02-03 is a more gradual rising from the back to the front where the 04-07 is quite a bit steeper. I'm pretty sure if you get one from Fobia he could help ya make it fit =)
  9. tangledupinblu
    Hmmm...maybe i'll just hack my stocker to bits and make it work somehow? Stupid SOA changing parts ftl.
  10. Deride
    I would have made the 05 one I have work but the previous owner cut the splitter part out thinking in "blocked" air flow. If you are going to modify one start with the STI one as it has a bigger surface area. I am interested in buying a modified splitter from fabiola if he modified the 2 he has to fit our scoops =)
  11. tangledupinblu
    I'll have to go and have a chat with him and take a look since he moved into my neck of dah woodz. I'll report back to ya. It may take a few tho as i have company coming for the weekend.
  12. fobiawrx
    fobiawrx Fabiola
    no luck. must of gave them away awhile back when i moved. i had boxes of car parts that i was trying to get rid of. must of been in them. sorry guy
  13. Tash
    Tash Well-Known Member
    You figure is usdm one will work or need jdm?
  14. tangledupinblu
    Dunno...i'd like to try it to see if i can make it fit. But it appears to be that i may have to order the JDM from Yah-pan.
  15. Tash
    I got the usdm if you wanna pick it up see if it will work
  16. tangledupinblu
    I would! Just not sure when i can make it to your place.
  17. Tash
    Busy man huh?
  18. tangledupinblu
    You know it! You going to Monticello to the Loch Jewelers meet tonight?
  19. Tash
    No finishing the car tonight for my alignment tomorrow so I can play this weekend
  20. tangledupinblu
    Well i'll see if i can figure out how to squeeze over there sometime. May be first of the week tho.
  21. phi11
    I think he found something......
  22. tangledupinblu
    :DYEAH!:D
    curly2k3 likes this.
