Hello all, I'm looking for the coupler that goes from the turbo to the intercooler for an 08 STI. Mine is torn up and needs to be replaced. If you have the entire y-pipe for a 04-13 STI, that should work as well. Thanks! Jordan
I found it was cheaper to just spend the $99 on the full GrimmSpeed Y-pipe kit (I tore mine too on the edge, turbo side). You're talking about the L-shaped one, right? It is $350 through Subaru.
Yep, found all that out, but I did also find this: http://www.oakos.com/Merchant2/merc...re_Code=355&Product_Code=E9051&Category_Code= I have a lead on a stock elbow, but thanks for the info. Did you find the Grimmspeed kit any more durable than the stock?
Looked pretty similar to stock, with a little bit more adjustability because of the multiple sections. If you can find an OEM part, it would be an easier install. Trimming down GS's was tedious. That said, it works fine.
