WTB: timing belt
Discussion in 'Want To Buy : Cars/Parts' started by 03suby, Oct 19, 2009.
  1. 03suby
    03suby Well-Known Member
    Application: 2003 WRX
    ej205
    Looking for a new timing belt that maybe someone got in a PCI kit and didn't use...?
    lf I can't find one I will just order a cloyes from Rock Auto for $40.
    thanks,
    jordan
  2. Bielke55
    Too Much Info!
    All timing belts are the same right?
  3. ofspunk7
    More details!
  4. Scuba Steve
    I must STRONGLY suggest that when it comes to the front of your motor anything less than OEM is not worth the risk! save your money and buy OEM with a MNSOC discount. Protect your investment:cool:
  5. 03suby
    Maybe I will reconsider the Cloyes decision.
    However, I know Mitsuboshi is the OEM belts used on the last 2002 WRX I worked on and that is the belt that is included in the PCI kit...
    Just trying to save some $$$. I know its not an area you should skimp. I already had to tear the motor apart once to check for valve/piston interference. Not looking to do that again.
    Mitsuboshi I would think to be good since the factory used them.?
