WTB: Tires
Discussion in 'Want To Buy : Cars/Parts' started by TheCocaColaMan, Sep 1, 2013.
  1. TheCocaColaMan
    TheCocaColaMan Well-Known Member
    I need a new set of tires and I will possibly do a rim and tire deal. Must have fairly good tread considering they have to make it through winter and then some. Rims must have minimal rashes but its not a huge deal if they have them I have already looked for them on the tires web sites just searching through my options before I pay big bucks for something someone my want to get rid of first. Also if anybody knows of any shop/store that has a good deals right now feel free to leave a comment.
    Tire size:195/50 or 205/50
    Rim size: 16's
    Thank you
  2. JasonoJordan
    If I can find a nice set of rims for my brz id have stock brz rims with 17" Bridgestone s-04 pole position tires 225 40 17's for sale $600 price range. Rims r mint and tires have less then 5k on them.
  3. TheCocaColaMan
    The only thing is im putting these on a 03 Mazda protege5 Think they will fit?
  4. JasonoJordan
    Well the brz rims are 5x100 so the rims wont work. I do have some Sti bbs rims but they are wider then the brz rim. Some people say they have ran 225 fine on the car others say it's a squeeze.
  5. tangledupinblu
    So do you need 5x114 or 5x100 rims? I know of some good deals, but need more info as i have no idea what a Mazda Protege runs for bolt patterns.
  6. JasonoJordan
    From what I found its 5x114
  7. tangledupinblu
    Hmmm, good luck finding 16's in 5x114!! Hopefully someone has something for ya.
  8. TheCocaColaMan
    5 star bolt pattern
  9. Bryan621
    Bryan621 Well-Known Member
    There are variations of a 5 lug patterns.. ie 5 x 100 and 5 x 114
  10. austinpike
    austinpike Well-Known Member
    Also Mazda centering hub is larger than Subaru... So you can put theoretically Mazda wheels on a Subaru (assuming the correct bolt pattern) - but to put Subaru-specific wheels on a Mazda you would need a spacer (or bore out the center.)
    http://www.mazda3forums.com/showthread.php?s=d6a7821e416934c98b3fc7630b62cb9b&t=341605
    http://www.dfwautoclub.com/forums/showthread.php?t=11963
    Basically you won't find much here, since anything 5x100 (ie, 97% of Subarus) won't fit your car, and anything 5x114 is is most likely going to be 17"+ diameter and 8"+ wide.
  11. TheCocaColaMan
    I see what your getting at and thank you for the bit of knowledge!
  12. 02_Rexxxy
    02_Rexxxy Active Member
    I have a set of 16" 98 Eclipse GS rims with blizzak snow tires close to 10/32 that I used for one season of ice racing on my old GSX I had. $400 pm for pics etc if you're interested. They are sitting in my storage shed and the size I believe is 205/50R16
