wtb transmission mount
Discussion in 'Want To Buy : Cars/Parts' started by immakhang, Oct 13, 2011.
  1. immakhang
    immakhang Well-Known Member
    lookimg for a transmission mount that would work for my 2000 2.5rs and not as bad as mine...
    thankx...
  2. Moleness
    If someone can chime in...I have one from an '04 STI and an '06 WRX, will they work? I feel like they might...
  3. blackozone
    I'm pretty sure they're the same. When I compared my STI stock mount to my old WRX mount, they looked the same.
  4. Threshld1
    Threshld1 Well-Known Member
  5. blackozone
    The STI mount has more rubber in it to resist movement. A 5-speed mount has the same mounting points, but there's less rubber in the actual mount.
  6. Moleness
    I can compare the 2 in my garage when I get a chance, but the real question here is...Will they work for the GC chassis?
  7. Threshld1
    Yes the 5mt mounts can be interchanged between GC/GD/BC/BD/BE. It does look like the 6mt is the same mounting set up also. Personally I would get the group n motor and transmission mounts and be done with it.
  8. Deride
    The 6MT mount itself is just a bit shorter. I know someone using a 6MT Group N mount on a 5MT tranny without any issues.
