Wtb wrist pin/piston pin tool
Discussion in 'For Sale : Car Parts' started by AWDmadness, Aug 4, 2008.
  1. AWDmadness
    AWDmadness Active Member
    Hey everyone i am trying to rebuild a few motors and i cant find anywhere to get the special tool to remove the wrist pins/ piston pins so i can split the case. Does anyone know where i can get one from or have one i can buy?
  2. fobiawrx
    fobiawrx Fabiola
    use a needle nose pliers to take out the clip. and use a long skinny rod to push them out from the other side.
  3. Ej22TIM
    Ej22TIM Well-Known Member
    you may also need bielkes custom piston removal tool, worked good on my block ;)
  4. Scuba Steve
    what fobia said. I actually think theres a DIY on youtube about this
  5. Deride
    I made one with a hood prop rod.
  6. piddster
    .25" steel rod bent in a vice works well.
  7. Deride
    Yea, get creative. I bet everyone has stuff laying around to make a wrist pin removal tool.
  8. AWDmadness
    i tried a heavy duty flat head screw driver, heated it up and bent it but i cant get the wrist pins to move. i guess i will try again
  9. piddster
    You need to be able to hit it with a hammer of some sort to pop it a bit. They can get pretty varnished in there.
