WTB: WRX 5spd swap parts (update in first post)
Discussion in 'For Sale : Car Parts' started by Substeroo, Feb 6, 2006.
  1. Substeroo
    Substeroo Well-Known Member
    UPDATE:
    I have:
    the tranny
    Pressure plate
    flywheel
    slave cylinder
    Now I need:
    Shifter,
    Shift linkage,
    Clutch,
    Pedal assembly,
    Flywheel bolts,
    Pressure plate bolts ,
    All of the hydraulic parts for the tranny,
    Starter
    Thanks!
  2. ShortytheFirefighter
    Finally converting the SVX? I'll see if I've got any of that stuff lying around the shop or the house. You can also check with Bikerboy, he might have some of the pedal assembly for sale.
  3. Substeroo
    Yup. Finally got the go ahead by all the determining elements and entities.
    Thanks Brian!
  4. 95lwrx
    95lwrx Well-Known Member
  5. Musashi
    I have a stock tranny mount and shifter if your interested!
  6. Substeroo
    Thanks you guys!
    I'll have to find out more about the ebay tranny.
    C-Man, Let me see if this ebay thing goes through, then I'll get back to you.
  7. Substeroo
    Okay so the ebay thing fell through.
    Any more ideas or help?
    Thanks!
  8. esperunit
    esperunit Well-Known Member
    car-part.com had a WRX tranny with 4k miles on it that was in a garage fire (it was fine) that they offered my 1500 shipped.
    It was located right across the border in wisconsin.
  9. Substeroo
    Thank you esperunit bump.
  10. Substeroo
  11. Substeroo
    I'm looking at a tranny that's in WI. Woohoo!
  12. kickin_81
    kickin_81 Well-Known Member
    Glad you found one! When are you gonna get it installed?
  13. tbone
    tbone Well-Known Member
    Correct if I'm wrong. I thouth the RS tranny are slightly stronger than the WRX trainne ratio. RS 4.11 to WRX 3.90
  14. Substeroo
    EDIT: Stronger? I don't know but, I would be better off with the WRX tranny.
    I'm not going to be able to install it yet.
    Here are some pics.
    He's also selling these gearsets and one has a broken 2nd gear.
    I might get those too and the other tranny carcass.
    I still need all the other parts for the swap though...hint hint.
  15. TSTRBOY2004
    I think you have strength and gearing mixed up in those numbers...
    I would say a WRX r=tranny is stronger cause NO japanese company I have ever known builds the faster more powerful car with a weaker smaller transmission then its N/A counterpart.. kinda backwards after sepdnign millions developing it...
    the gear ratios determine acceleration or top / final speed.....
  16. Substeroo
    To bump or not to bump?
  17. kickin_81
    I have always thought that the gears were manufactured from Subaru from the same type of assembly line for all trannies minus the STi/LGT gears. In the STi trannies, Subaru made sure that we all knew that their 6-speed tranny gears were a lot stronger than their typical trannies. To the best of my knowledge back when the WRX was the new kid on the block in 2001, Subaru never stated the increased strength and integrity of the WRX's longer geared tranny gears. I still believe, as a general rule, the shorter RS gears will not break before the WRX gears given the same HP output of the motor and the same driving style of the driver. Shorter gear ratios are larger gears which in turn has more teeth per gear thus can handle more power (before anthing begins to break). Don't get me wrong, it's not a world of a difference like the comparison of the WRX gears to the STi gears. I'm talking in general given that all else are equal.
  18. Substeroo
    Fong, are you saying I can have your shifter and pedal box for 20 bucks?
  19. kickin_81
    I don't have one for sale, but if I did and no one else is bidding $21 or more for them, you'll be my first customer. :p
  20. Substeroo
  21. Substeroo
  22. Substeroo
  23. LVT
    LVT Well-Known Member
    the RS tranny should hold up the svx with no problem. it also has better gearings for better acceleration than that of the WRX. you'll be much faster.
  24. Substeroo
    Thanks Lue but, I already have a WRX tranny in my garage. :)
  25. LVT
    either way, you'll love the 5spd
  26. Substeroo
    I am really getting excited about getting it in. Once the weather warms up, I'm going to want to have that on the road.
  27. Substeroo
    bump for today :D
  28. Substeroo
  29. snbrd4evr
    snbrd4evr Well-Known Member
    That's really too bad you already have the wrx tranny, I could sell you my RS tranny, exedy clutch, act lightweight flywheel, diffs, hubs, everything except the pedal box for a pretty decent price. I'm putting a 96 jdm tranny into my RS while I'm swapping motors ;) .
  30. Substeroo
    Yeah I got the tranny for a good price. Is the pedal box for a hydraulic clutch assembly? If it is, I wonder if it would work?
  31. snbrd4evr
    I can't really tell if you're asking me or not. I can't sell my pedal box so I don't know what you're asking. sorry :)
  32. Substeroo
    I was wondering if you were open to selling the pedal box if it would work with my setup. Thanks!
  33. Substeroo
  34. snbrd4evr
    I see.... sorry about that. I'm going to need my pedal box but I'm sure you could try to pick one out of a wrecked car... maybe Mike's old rally car. I'm not set on a price yet but I'm checking to see what the going rate is and then I'll drop a little off for mnsubaru people :)
  35. Substeroo
    uber-bomp
  36. Substeroo
    buggy baby bumpers
  37. Substeroo
    new site bump
  38. curly2k3
    nice! another SVXer, are you a member on subaru-svx? those guys can help out a lot...
  39. Substeroo
    buuuuuuump for spring
  40. Substeroo
    Yes I am sir. Thank you!
  41. Substeroo
    pmub sdrawkcab
  42. Substeroo
    bump for nice day.
