WTBorrow Clutch alignment tool
Discussion in 'For Sale : Car Parts' started by wrxpeed, Oct 29, 2007.
  1. wrxpeed
    wrxpeed CobraPeed
    I'm doing my 5mt swap this weekend and need a clutch alignment tool. Anyone around here have one to borrow to me?
    Thanks,
    Bryan
  2. Dynapar
    Talk w/ fuji. he is pro at lining up clutches.
  3. Jackstand
    Jackstand Well-Known Member
    Yeah he uses is finger alignment tool :biggrin:
  4. mayhem83
    mayhem83 Well-Known Member
    I have a metal one (from a busted trans) you can use but you will need to come to Stacy to get it. Let me know.
    Mark Utecht
  5. readymix
    I have one you can borrow. I'll grab it. When do you need it?
  6. wrxpeed
    wrxpeed CobraPeed
    thanks, but it looks like the mix has me covered.
    Cool. I'll need it this weekend, most likely saturday since friday night is when I'll be pulling all the Auto stuff. I could swing down and meet you somewhere friday night.
    Thanks
  7. readymix
    NP man. I'll PM you my cell number. We could meet at Firestone on Friday. Don't know how far that is for you, it takes me about 20min to get there. Whatever, we can figure it out later.
  8. Chux
    I'm not sure if this works on EJ-series trans's.....the starter hole might not be in the right place. but on the EA ones, you can reach the PP to flywheel bolts through the starter hole. put the clutch kit together as you would normally, but only put those bolts in finger tight. than the clutch disc can move around under the PP. making mating the engine and trans about 45 million times easier.....
    than just tighten those bolts through the starter hole by turning the engine over from the crank bolt.
  9. wagonL
    wagonL Well-Known Member
    tsk tsk tsk...fuji likes to put his finger in a lot of things :p...
    mechanically wise...
  10. wrxpeed
    wrxpeed CobraPeed
    the Firestone is good for me if its good for you friday evening.
  11. readymix
    Done and done. I'll be there Friday with the alignment tool.
