WTBorrow: Rear main install tool
Discussion in 'For Sale : Car Parts' started by Threshld1, Aug 15, 2007.
  1. Threshld1
    Threshld1 Well-Known Member
    SLP
    Hey guys,
    Going to be changing gearboxes and clutch this weekend. I have a new rear main i would like to install. I dont want to risk it leaking due to improper seating. If anyone has the proper size drift/install tool i could borrow i would much appreciate it. Let me know. Thanks!
  2. Threshld1
    SLP
  3. FuJi K
    St. Paul, MN
    You know what I used??? I used that automatic tranny plate, which bolts onto the torque convertor and 4 auto flywheel bolts. Gradually tighten them up and you get it to be flush with the crank. Then I use a BIG 32mm socket and slowly work around seal until it's flush with the block. Works just fine!
