wtbvg: ej turbo parts
Discussion in 'For Sale : Car Parts' started by mnlegacy, Aug 10, 2005.
  1. mnlegacy
    mnlegacy New Member
    i am looking for turbo exhaust m,anifolds, stock or aftermarket that will fit ej22 heads, the n/a motor, alsao looking for stock turbo, charge piping, etc. thansk all hoping to buy asap
  2. kickin_81
    kickin_81 Well-Known Member
    Just to be the devil's advocate, some NA heads are single port. The turbo heads are dual port. If you find that your motor has single ported heads, you'll need to have the EJ22T/EJ20T heads to fit a turbo manifold.
    We will better help you if we know what you're planning to do.
  3. readymix
    I have a stock Uppipe if you need it. You will want to gut the cat out of it, but I'll sell it to you for 30 bucks.
  4. readymix
    Also, I have a set of EJ22T heads that will be coming up for sale.
  5. mnlegacy
    mnlegacy New Member
    what do u mean dual/ single port, the manifold openiings? if so there are two intake,a dn two exhaust on each side( two intake logs, two exhaust outlets
  6. mnlegacy
    mnlegacy New Member
    o yea also, i am looking to turbo my n/a
  7. AWDimprezaL
    then a turbo manifold would bolt up to your car, since you are dual port, im doing the same thing to my impreza...na/to turbo but i need to get turbo heads
  8. mnlegacy
    mnlegacy New Member
    do i have to use the turbo heads, or r u just using them cuz they are better?
  9. readymix
    Oh, snap. The Turbo heads are sold...my bad
  10. AWDimprezaL
    you dont have to...but it will lower your comp ratio a bit, and the heads will flow better
  11. FuJi K
    93-95 2.2L dual ports
    96-01 2.2L single ports
