WTT: for Stock Manifold
Discussion in 'For Sale : Car Parts' started by mnstilynwrx, Jul 8, 2009.
  1. mnstilynwrx
    mnstilynwrx Well-Known Member
    I need a Stock Manifold for a 02 wrx. Iam willing to trade for mine once it is out on sunday. It is tapped for an EGT and iam returning my car back to stock. let me know what you have.
  2. blackozone
    Is yours a stock manifold with EGT tap then?
  3. mnstilynwrx
    Yes. its stock with the EGT tap.
  4. Dynapar
    I have one that is just sitting around right now. It needs the bolts that connect the drivers side collector the the X-pipe, but I already have a new OEM gasket for that connection. I believe I have most of the stock heat shields as well, although only a small portion of those bolts. What cylinder is yours tapped on? is it the 1/8 NPT threading? I have been looking at getting mine tapped. So a trade would work well for me. I can snap some pictures of it if you want.
    shoot me a pm if you are interested.
  5. jb05sti
    jb05sti Well-Known Member
    why waste the time taking it off....put a bolt in it.
  6. Dynapar
    ^ I dont think having a tapped manifold w/ a bolt in it qualifies for "stock" if someone looks at it. besides its only like 8 bolts to take it out.
  7. mnstilynwrx
    cause iam taking up pipe and turbo out so might as well fix it and return back to STOCK. I dont think a bolt is that safe..
  8. piddster
    Get a steel 1/8 NPT plug and be done with it.
    A bolt will not stay in the hole with tapered pipe threads.
  9. blackozone
    I'm an idiot about the thread pitches for the taps.
    Would it fit the EGT setup that comes with Defi gauges?
    My stock manifold is complete, not dismantled. Comes with heat shields and bolts needed.
  10. mnstilynwrx
    I dont know maybe some one else would know.. I dont see why not. Iam assuming that the sensors are pretty much the same in size for all gauges?.. If some one else can chime in that would be cool. If it will work i will trade
  11. piddster
    All the K-type thermocouples I've seen for various gauges and datalogging setups use 1/8 NPT threads.
  12. blackozone
    Do you know which runner the EGT bung is tapped in?
    Also, when would you want to get these traded?
  13. mnstilynwrx
    I dont. I had some one do it for me so i didnt look. As soon as possible! were u located?
  14. blackozone
    I'm in Rochester, MN. I can see if someone can deliver to Firestone tomorrow night, otherwise I wouldn't be able to make it until next weekend.
  15. mnstilynwrx
