FAIL: Whiteline Endlink
Discussion in 'Modifications And Maintenance' started by Schlanseay, Apr 25, 2013.
  1. Schlanseay
    Schlanseay Member
    Installed my 24mm Front sway with adjustable end links and 22 Rear sway with adjustable end links last weekend and have been taking it easy daily driving my 5 miles to work and back.
    Went under the car to double check and tighten things up if needed and found this on my rear passenger side. I don't know when it happened and nothing else looked damaged so I put the stock back on in the mean time.
  2. MNBD
    MNBD Member
    Wow, that's scary stuff. At least you weren't pushing the car when it happened, you know? Is there any damage to the others?
  3. Schlanseay
    Schlanseay Member
    I know, that what I told WL when I emailed them. Nothing else seemed to be damaged at all besides the strut sticker where it looked like it rubbed. a bit. Hopefully the Stocker's hold up for a little while.
  4. ShortytheFirefighter
    ShortytheFirefighter Emma said I'm a nice guy, so there. Staff Member
    Kartboy or bust when it comes to endlinks.
    predavore and KA-T_240 like this.
  5. kongzilla
    kongzilla Well-Known Member
    that looks like a bracket problem and not an endlink problem.
  6. mke723
    mke723 Well-Known Member
    so, im unfamiliar with the newer suspensions, i have an 07.. i have gathered from the broken weld that that bracket that is bolted to the endlink, is/was attached to that tube next to it in the first pic. Was that a white line piece, or a subaru piece?
  7. Shane86
    Shane86 Well-Known Member
    This.
    The endlink looks perfectly fine.
    I had to do a little research on just how that attaches. kinda weird.
    But I've had nothing but excellent customer support from whiteline over the years, even when their product wasn't the cause of the issue, they took care of me. I'm sure it'll be fine.
    Where did you buy the kit from? they may have already made a revision, and that was just an old kit.
  8. Shane86
    The metal tube bridges the inside of the LCA, and the bolt goes through the whole thing. that bracket welds to it, and provides a parallel attachment point for the swaybar instead of having to rotate 90* in the link.
  9. mke723
    i under stand how it mounts
    my question is: is that mounting point from subaru, or is it from white line..?
  10. Shane86
    That bracket is from whiteline.
    the normal end link from that car just turns 90* at one end, and has no bracket.
  11. mke723
    ahh. ok... looks like they took the cheap route... that would be much stronger if they just rolled a heavy gauge piece to form a b or d and put the holes in the top leg and welded it along the seam....
    or just machined a piece..
  12. ofspunk7
    Looks like you need the updated kit
  13. Shane86
    Agreed.
    I was just making a hypothesis.. unless you know whiteline has updated their kit?
  14. ofspunk7
    My bad. Read that wrong
  15. Schlanseay
    Schlanseay Member
    Just talked to WL and they do have an updated link/kit it's the klc 182 and it more closely resembles the Kartboy design than the bracket/link design of the broken klc 166. They were very fast and over nighting the 182's free of charge. I'll update with pics when I put them on this weekend.
    MightyP and ofspunk7 like this.
  16. Shane86
    Once again, Whiteline customer service is top notch. I knew they'd take care of you!
  17. Schlanseay
    Schlanseay Member
    So I got my new endlinks today overnighted free of charge from Whiteline and they are a much better design and a bit more beefy.
    Installed
  18. Shane86
    Wow.. that's some serious hardware.
    And it'll even be easier to adjust with the middle nut like it is.
  19. Schlanseay
    Schlanseay Member
    Very easy to adjust "on the fly" and fine tune.
  20. MNBD
    MNBD Member
    Very nice! Hearing good customer support stories like this make me even more inclined to buy their products. Glad to hear everything worked out! The new product looks MUCH nicer.
  21. scoob
    scoob Member
    i have to get me some of thoses
Share This Page
